表面活性剂是商用洗涤剂的主要成分,由于具有洗涤性能、吸湿性、渗透性、溶解性、分散性、润滑性、抗静电性、杀菌性和防锈性等多种性能,被广泛应用于各种工业和制药领域。非离子表面活性剂具有亲水基团,即使溶解在水中也不会离子化。由于它几乎不受水硬度和电解质的影响,因此可以与所有其他表面活性剂一起使用。鉴于其性质,非离子表面活性剂的使用量急剧增加,并指出了其对环境的影响。自2003年以来,非离子表面活性剂一直是《水质控制标准》的检测项目。这一次,使用具有二氧化硅NH2柱的ELSD检测器在HILIC模式下测量和分析作为非离子表面活性剂样品的Triton X-100和 Polyethylene Glycol 400。UASGOApplication Note 2/3Application NoteAnalysis of Cyclodextrines in Green Tea using HPLC-ELSD Analysis of Cyclodextrines in Green Tea using HPLC-ELSD Surfactants are well known as a main constituent of commercial detergent a nd is widely used in various in d ustrial and pharmaceutical f ield s due to various capabilities such as washing performance, moisture absorbency, osmosis, solubility, dispersibility,lubr i c i ty, antistatic ability , bactericidal property and anti -rust property. Nonionic surfactants have hydrophilic groups which are not ionized even when dissolved in water . Since it is hardly aff e cted by water hardness and electrolytes, it can be used together with all other surfactants. Consider i ng its nature , the usage of nonionic surfactants have i ncre a sed dram a tically and its affect on the environment has been pointed out. Since 2003,nonionic surfactants have been the test i tem for Water Quality Control Standards. This time , Triton X-100 and Polyethylene Glycol 400 as no n ionic surfactant samples were measured and analyzed using an ELSD detector with Sil i ca NH2 column in HILIC mode. Keyword : Cyclodextrine, HILIC, polymer NH2column, ELSD, a-Cyclodextrine, b-Cyclodextrine,g-Cyclodextrine PU-2089 Pump: PU-2089 Column: Shodex Asahipak NH2P-50 4E (4.6mmlD x250 mmL) Autosampler: AS-2057 Eluent: Water/Acetonitrile (40/60) Column oven: CO-2060 Column temp.: 50°C Detector: ELS-2040 ELSD condition: Nebulizer temp.: 30℃ Evaporator temp.: 30℃ Injection volume: Gas flow rate; 1.4 SLM 10pL Standard sample: a, b, g-Cyclodextrine 0.5 mg/mL each in Water/Acetonitrile (40/60) Resul t s and D i scussion Figu r e 1 s h ows t he chr o m at ogr a m o f a,b, g -C y cl o d e xtr i n e . F i g u re 1. C hro m a tog r am of th e standard mix t ur e o f Cycl o d e x t rine 1: a-Cyclod e xtrin e , 2: g -Cyclod e xtrine ,3: b-Cyclodex t ri n e Figu r e 2 s h ows th e chr om a t og r a m o f gr e e n t e a m ix e d with c y c l o d ex tr i n e . A l l th e c o m p o n en ts wer e de t e c t ed wi th th e q ua n t i t a t i ve r es u l t : a -Cy clod e x t r i ne 4.5 m g /10m L , b -Cy c l o d e x tr ine 5.0 mg /10mL,g -C y cl o de x tr i n e 22.7 mg/10m L. Figure 2. C h romatogra m of green tea m i x ed wit h cyclodex tr i n e1: a-Cyclodext r i n e, 2: g-Cyclodex t ri n e , 3: b-Cyc l odextri n e Sa m ple p rep arat i o n : G r ee n te a combined with cyclod e xtr i ne was mixed with mobile ph ase of the same amount and was t h e n s e n t t h rou gh a 0.45pm f i lt e r.
关闭还剩1页未读,是否继续阅读?
佳士科商贸有限公司为您提供《绿茶中环糊精的HPLC-ELSD分析》,该方案主要用于茶叶中环糊精、HPLC-ELSD分析检测,参考标准《暂无》,《绿茶中环糊精的HPLC-ELSD分析》用到的仪器有JASCO高效色谱仪LC-4000。
