Column: ChromCore AR C18, 1.8 μmDimension: 2.1×100 mmMobile Phase: A) 0.3% FA in H2O B) 0.3% FA in MeCNGradient: t(min) %A %B 0 99 1 1 99 1 2 50 50 3 50 50 3.1 99 1 4.5 99 1Flow Rate: 0.2 mL/minTemperature: 40 ℃Injection: 10 μLDetection: ESI (-)Samples: Eight Organic AcidsPeaks: 1. Fumaric Acid (延胡索酸) 2. Succinic Acid (琥珀酸) 3. L(-)-Malic Acid (L-苹果酸) 4. α-Ketoglutaric Acid (α-酮戊二酸) 5. Citric Acid (柠檬酸) 6. Isocitric Acid (异柠檬酸) 7. Pyruvic Acid (丙酮酸) 8. Cis-Aconitic Acid (顺乌头酸)8种有机 酸 Column: ChromCore AR C18,1.8 pm Dimension: 2.1×100mm 100- Mobile Phase: A) 0.3% FA in H20 0- B) 0.3% FA in MeCN 100- Gradient: t(min) %A %B 0- 0 1 1 1 100- 0 2 3 58 100- 3.1 1 三 9994.591 100- Flow Rate: 0.2 mL/min 0二 Temperature: 40℃ Injection: 10 pL 100一 Detection: ESI (-) 0 Samples: Eight Organic Acids 100- RT:2.57AA:623146SN: 1190 延胡索酸0.841.041.23 1.49 1.62 1.67 2.06 2.33 2.72 2.88 3.07 3.253.403.553.733.924.14 4.22 RT:2.36AA: 1623403SN: 3279 琥珀酸0.83 1.06 1.21 1.47 1.63 1.71 2.03 2.11 2.562.73 2.95 3.02 3.27 3.613.73 3.81 4.07 4.15 4.33 RT:1.63AA:4968791 SN: 3632 L-苹果酸 0.890.971.23 1.40 2.022.112.29 2.48 22.702.90 3.183.40 3.54 3.62 3.793.98 4.15 4.49 RT:2.03AA: 1455405SN: 1258 α-酮戊二酸0.84 1.01 1.28 1.43 1.65 1.73 2.12 2.2822.55 2.69 2.80 2.97 3.20 3.35 3.65 3.773.97 4.09 4.21 4.38 RT:2.05 AA: 17740934 SN: 6539 柠檬酸 1.630.87 0.961.23 1.48 1.94 2.222.34 2.59 2.76 2.93 3.10 3.21 3.63 3.72 3.81 3.964.14 4.30 RT:1.63AA:4515413SN: 3127 异柠檬酸 0.85 0.951.23 1.38 2.05 2.17 2.33 2.47 2.60 2.78 2.96 3.113.363.59 3.70 3.84 4.04 4.154.40 丙酮酸 RT: 1.79AA:929201SN: 540 0.89 0.96 1.22 1.43 1.60 2.02 2.082.362.612.7993.01 3.10 3.31 3.473.76 3.84 3.92 4.08 4.46 RT:2.56 AA: 1249100 顺乌头酸 SN: 1214 0.87 0.97 1.26 1.331411.66 1.80 2.06 2.41 2.71 2.85 3.07 3.203.47 3.58 3.72 3.81 3.95 4.19 4.35 Peaks: 1. Fumaric Acid (延胡索酸) 2. Succinic Acid (琥珀酸) 3. L(-)-Malic Acid (L-苹果酸) 100一 三 4. a-Ketoglutaric Acid (α-酮戊 二 酸) 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 T i me (m i n ) 5. Citric Acid (柠檬酸) 6. Isocitric Acid (异柠檬酸) 7. Pyruvic Acid (丙 酮酸) 8. Cis-Aconitic Acid (顺乌头酸)
关闭产品配置单
纳谱分析技术(苏州)有限公司为您提供《8种有机酸在ChromCore AR C18色谱柱上的分离》,该方案主要用于化药制剂中含量测定检测,参考标准《暂无》,《8种有机酸在ChromCore AR C18色谱柱上的分离》用到的仪器有纳谱分析 UHPLC色谱柱 ChromCore UHPLC色谱柱、纳谱分析 ChromCore AR C18色谱柱。
