使用电感耦合等离子体质谱法(ICP-MS)测定体外人视网膜色素上皮细胞(HRPEsv 细胞系)模型分泌的外泌体(<200 nm 细胞外囊泡)中的内源性Fe、Cu和Zn。将经2,2'-偶氮二(2-甲基丙脒)二盐酸盐 (AAPH) 诱导氧化应激 (OS) 条件处理的细胞的结果与未处理(对照)细胞进行比较,以评估两组之间金属成分可能存在的差异。为进行ICP-MS分析,研究测试了三种样品导入系统:一种微型雾化器和两种单细胞雾化系统(作为总消耗装置),发现其中一种单细胞系统(以批量模式运行)最适合本项测试。本研究分别基于差速离心法和聚合物试剂沉淀法,研究了从细胞培养基中分离外泌体的两种方案。透射电子显微镜测量结果显示,与差速离心法相比,沉淀法纯化的外泌体尺寸更小、更均匀(差速离心法:20-180 nm,沉淀法纯化:15-50 nm),颗粒浓度更高。不过,与差速离心法相比,聚合物沉淀法会显著升高Fe, Cu和Zn的本底。考虑到HRPEsv细胞系外泌体中被评估的内源元素浓度较低,放弃了基于聚合物的沉淀方法。在比较对照组和经OS处理的HRPEsv细胞样本中的金属含量时,Fe和Cu的结果在统计学上较为相近。然而,在OS条件下,Zn含量上升(对照组11 μg L-1 ,OS处理组:34 μg L-1),这表明OS诱导的分泌活动会消耗Zn,这是RPE细胞抗氧化能力的基础。 The determination of endogenous Fe, Cu and Zn in exosomes (<200 nm extracellular vesicles) secreted by an in vitro model of the human retinal pigment epithelium (HRPEsv cell line) was carried out by inductively coupled plasma - mass spectrometry (ICP-MS). Results for cells treated with 2,2′-azobis (2-methylpropionamidine) dihydrochloride (AAPH) inducing oxidative stress (OS) conditions were compared with non-treated (control) cells in order to evaluate possible differences in the metal composition between both groups. Three sample introduction systems were tested for ICP-MS analysis: a micronebulizer and two single cell nebulization systems (as total consumption set-ups), being found one of the single cell systems (operating in bulk mode) as the most suitable. Two protocols for the isolation of exosomes from cell culture media were investigated based on differential centrifugation and precipitation with a polymer-based reagent. Transmission electron microscopy measurements showed smaller and more homogeneous sizes (15–50 nm versus 20–180 nm size range) together with a higher particle concentration for exosomes purified by precipitation compared to differential centrifugation. However, it was observed that the contribution of polymer-based protocol to the Fe, Cu and Zn blank was significant as compared to the differential centrifugation protocol. Therefore, considering the low concentrations of the evaluated endogenous elements in exosomes from the HRPEsv cell line, the polymer-based precipitation method was discarded. When comparing metal levels in samples from control versus OS-treated HRPEsv cells, results for Fe and Cu were statistically similar. However, upregulation of Zn was found during OS conditions (11 versus 34 μg L−1 in control and OS-treatment, respectively), showing Zn depletion through secretory activity induced by OS, underlying the antioxidant ability of RPE cells.
关闭还剩6页未读,是否继续阅读?
上海凯来仪器有限公司为您提供《使用ICP-MS测定氧化应激条件下人视网膜色素上皮体外模型分泌的细胞外囊泡中的内源性微量元素》,该方案主要用于其他中内源性Fe、Cu和Zn检测,参考标准《暂无》,《使用ICP-MS测定氧化应激条件下人视网膜色素上皮体外模型分泌的细胞外囊泡中的内源性微量元素》用到的仪器有microFAST SC 单细胞/单颗粒样品引入系统。
