检测样品 锂电池
检测项目 理化性能
钻石会员 3284 篇解决方案
The lithium-ion battery (LIB) industry requires the analysis of the elemental composition of materials at all stages of production (1). To prevent contamination of LIBs from impurities, suppliers of the chemicals used to produce cathode, anode, and electrolyte materials must quality assure (QA) their products using reliable, reproducible, and robust techniques. The accurate analysis of elemental impurities in the chemicals is especially important as these elements can affect the final performance of the battery.
关闭还剩6页未读,是否继续阅读?
安捷伦科技(中国)有限公司为您提供《Determination of Trace Metal Impurities in High Purity Aluminum Nitrate using ICP-OES》,该方案主要用于锂电池中理化性能检测,参考标准《暂无》,《Determination of Trace Metal Impurities in High Purity Aluminum Nitrate using ICP-OES》用到的仪器有Agilent 5800 ICP-OES。
