检测样品 固体废物
检测项目 SVOCs
钻石会员 3278 篇解决方案
IntroductionGC/MS is regarded as the select analytical technique for the analysis of SVOCs. Governmental regulatory authorities have established methods and performance criteria for the measurement of SVOCs identified as pollutants in nvironmental and industrial matrices. For example, the U.S. EPA method 8270 (versions 8270D and 8270E) contains a list of over 200 compounds suitable for analysis by GC/MS in solid waste, soil, air, and water extracts.1,2 Method 8270 contains SVOCs across several analyte class types from acids, bases, neutral compounds, and polyaromatic hydrocarbons (PAHs); this method also has detailed specifications and requirements for the Quantitative Analysis of SVOCs
关闭还剩14页未读,是否继续阅读?
安捷伦科技(中国)有限公司为您提供《nalysis of Semivolatile Organic Compounds Using Hydrogen Carrier Gas and the Agilent HydroInert Source by Gas Chromatography/Mass Spectrometry》,该方案主要用于固体废物中SVOCs检测,参考标准《暂无》,《nalysis of Semivolatile Organic Compounds Using Hydrogen Carrier Gas and the Agilent HydroInert Source by Gas Chromatography/Mass Spectrometry》用到的仪器有 Agilent 5977C GC/MSD。
