检测样品 环境水(除海水)
检测项目 有机污染物
钻石会员 3284 篇解决方案
IntroductionThe analysis of SVOCs can be challenging as there is a wide variety of target analytes that include bases, neutrals, and acids. These analytes span a wide range of molecular weights and boiling points. The United States Environmental Protection Agency (US EPA) has issued regulations and guidelines in Method 8270E for the analysis of these analytes by GC/TQ. Typical samples that are analyzed for SVOCs include surface or ground water as well as solid samples. These samples are then extracted before analysis. If method sensitivity can be improved,there is an opportunity to reduce sample and extract volumes that can result in decreased costs and increased lab sustainability. A preferable analytical method can also demonstrate a widedynamic range to reduce the need for sample dilution and reanalysis
关闭还剩13页未读,是否继续阅读?
安捷伦科技(中国)有限公司为您提供《Analysis of Semivolatile Organic Compounds with US EPA 8270E Using the Agilent 7000E Triple Quadrupole GC/M》,该方案主要用于环境水(除海水)中有机污染物检测,参考标准《暂无》,《Analysis of Semivolatile Organic Compounds with US EPA 8270E Using the Agilent 7000E Triple Quadrupole GC/M》用到的仪器有Agilent 7000E 三重四极杆气质联用系统。
