检测样品 酱腌菜
检测项目 /
钻石会员
3279 篇解决方案
IntroductionConcern about trace-level food contaminants is driving the demand for robust, rapid, and reliable methods for identification and quantitation of chemical residues and contaminants in food matrices. Usually, the detection methods such as triple quadrupole GC/MS and triple quadrupole LC/MS are aimed at a specific list of targets that are commonly found in food samples. These methods can be effective but may overlook any residues that are not specifically targeted. The approach to overcome this challenge is to perform untargeted screening of the sample intending to find as many compounds of concern as possible and allowing for retrospective analysis. Untargeted screening can be accomplished by analyzing the sample in full scan data acquisition mode.1,2 However, targeted triple quadrupole GC/MS (GC/TQ) analysis has an advantage of higher sensitivity and selectivity for the target analytes when compared to full scan analysis. The novel simultaneous dynamic MRM and scan (dMRM/scan) allows for acquiring both targeted dMRM GC/TQ data for target quantitation as well as full scan data for unknowns screening. Also, the simultaneous dynamic MRM and scan (dMRM/scan) deliver confident identification based on spectral library matching
关闭还剩12页未读,是否继续阅读?
安捷伦科技(中国)有限公司为您提供《Dynamic MRM/Scan Mode: Adding More Confidence to Sensitive Quantitation in Complex Foods by Triple Quadrupole GC/MS (GC/TQ)》,该方案主要用于酱腌菜中/检测,参考标准《暂无》,《Dynamic MRM/Scan Mode: Adding More Confidence to Sensitive Quantitation in Complex Foods by Triple Quadrupole GC/MS (GC/TQ)》用到的仪器有Agilent 7000E 三重四极杆气质联用系统。
