水中小液滴的形变,拖拽及磁支撑的实验和建模研究检测方案(粒子图像测速)
检测样品
其他
检测项目
关联设备
共3种
下载方案
The distortion, drag and break-up of drizzle droplets subjected to strong aerodynamic
forces was investigated to understand the pre-impact behaviour of droplets in aircraft
icing from supercooled freezing drizzle. The objective was to obtain a formulation and
data for the drag properties of droplets distorted by the aerodynamic forces, which were
beyond the scope of available experimental and modelling methods.
A practical and efficient semi-empirical computer model was developed for small water
droplets in air, 100μm < D < 500μm, at moderate Reynolds numbers, 350 < Re < 1500,
and high Weber numbers 3 < We < 20. This used available experimental terminal velocity
data for free-falling droplets, extrapolated to higher Weber numbers, and the numerical
solution for sessile droplets on a horizontal unwettable surface, with corrections for
the Reynolds number.
北京欧兰科技发展有限公司为您提供《水中小液滴的形变,拖拽及磁支撑的实验和建模研究检测方案(粒子图像测速)》,该方案主要用于其他中小液滴的形变,拖拽及磁支撑的实验和建模研究检测,参考标准《暂无》,《水中小液滴的形变,拖拽及磁支撑的实验和建模研究检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、Imager sCMOS PIV相机、PLIF平面激光诱导荧光火焰燃烧检测系统。
我要纠错
