Charles T. Campbell Studies of model catalysts with well-defined surfaces combining ultrahigh vacuum surface characterization with medium- and high- pressure kinetics Advances in Catalysis, 1989, 36, 1-54
R. R. Ford Carbon monoxide adsorption on the transition metals Advances in Catalysis, 1970, 21, 51-150
Pieter L. J. Gunter, J. W. Niemantsverdriet, Fabio H. Ribeiro, Gabor A. Somorjai Surface Science Approach to Modeling Supported Catalysts Catalysis Reviews: Science and Engineering, Volume 39, Issues 1-2, Pages 77-168 (1997)
Helmut Poppa Nucleation, Growth, and TEM Analysis of Metal Particles and Clusters Deposited in UHV Catalysis Reviews: Science and Engineering, Volume 35, Issue 3, Pages 359-398 (1993)
Earl L. Muetterties Molecular Metal Clusters as Catalysts Catalysis Reviews: Science and Engineering, Volume 23 Issues 1-2, Pages 69-87 (1981)
M. P. Hooker and J. T. Grant The use of Auger electron spectroscopy to characterize the adsorption of CO on transition metals Surface Science, Volume 62, Issue 1, January 1977, Pages 21-30
G. Doyen and G. Ertl Theory of carbon monoxide chemisorption on transition metals Surface Science, Volume 43, Issue 1, May 1974, Pages 197-229
