【求助】(已应助)J.C 80.90年代文献数篇,请大家帮忙!
  • fengxuezhang200
    2008/01/19
文献检索-互助
  • 给楼主提个建议:
    1.求助的标题最好列明是那个数据库的,而不是期刊的名称,那样不易查找!
    2.求助的文献整理一下,太杂乱了,应助的人根本就没有心情去看!
    3.对于求助的文献,一定要采用数字标明号码(建议采用数字,然后另起一行书写文献的形式),并且要保证清晰!
    例子:
    文献1).
    Response to comments on the H-ZSM-5 catalyzed formation of ethylene from methanol
    4.求助的文献一次不要太多,分批、分天的求助越容易得到解决!
    5.若能够给出数据库的连接,你得到应助的时间越早!
    ——————By xiaohaicph
    【作者】Ralph M. Dessau
    【文题】Response to comments on the H-ZSM-5 catalyzed formation of ethylene from methanol
    【期刊名,年份,卷(期),起止页码】Journal of Catalysis
    Volume 103, Issue 2, February 1987, Pages 526-528
    【作者】Tom Mole
    【文题】Comments on the H-ZSM-5 catalyzed formation of ethylene from methanol or higher olefins
    【期刊名,年份,卷(期),起止页码】Journal of Catalysis, Volume 103, Issue 2, February 1987, Pages 524-525
    【作者】Waqar R. Qureshi and James Wei
    【文题】One- and two-component diffusion in zeolite ZSM-5 II. Experimental
    【期刊名,年份,卷(期),起止页码】Journal of Catalysis, Volume 126, Issue 1, November 1990, Pages 147-172
    【作者】O. A. Sinitsyna, V. N. Chumakova and I. F. Moskovskaya
    【文题】Formation of aromatic hydrocarbons during conversion of methanol
    【期刊名,年份,卷(期),起止页码】Petroleum Chemistry U.S.S.R., Volume 27, Issue 1, 1987, Pages 56-62
    【作者】R. A. Comelli and N. S. Fígoli
    【文题】Effect of pressure on the transformation of methanol into hydrocarbons on an amorphous silica—alumina
    【期刊名,年份,卷(期),起止页码】Applied Catalysis, Volume 73, Issue 2, 13 June 1991, Pages 185-194
    【作者】S. Cavallaro, L. Pino, P. Tsiakaras, N. Giordano and B. S. Rao
    【文题】Alkylation of toluene with methanol III: Para-selectivity on modified ZSM-5 zeolites
    【期刊名,年份,卷(期),起止页码】Zeolites, Volume 7, Issue 5, September 1987, Pages 408-411
    【作者】V. Udaya, S. Rao and Robert J. Gormley
    【文题】Bifunctional catalysis in syngas conversions
    【期刊名,年份,卷(期),起止页码】Catalysis Today, Volume 6, Issue 3, January 1990, Pages 207-234
    【作者】R. M. Dessau
    【文题】On the H-ZSM-5 catalyzed formation of ethylene from methanol or higher olefins
    【期刊名,年份,卷(期),起止页码】Journal of Catalysis, Volume 99, Issue 1, May 1986, Pages 111-116
    【作者】T. Mole and J. A. Whiteside
    【文题】Conversion of methanol to ethylene over ZSM-5 zeolite in the presence of deuterated water
    【期刊名,年份,卷(期),起止页码】Journal of Catalysis, Volume 75, Issue 2, June 1982, Pages 284-290
    【作者】T. Mole
    【文题】Conversion of methanol to ethylene over ZSM-5 zeolite: A reexamination of the oxonium-ylide hypothesis, using 13carbon- and deuterium-labeled feeds
    【期刊名,年份,卷(期),起止页码】Journal of Catalysis, Volume 84, Issue 2, December 1983, Pages 423-434
    【作者】Don S. Santilli
    【文题】The mechanism of aromatic transalkylation in ZSM-5
    【期刊名,年份,卷(期),起止页码】Journal of Catalysis, Volume 99, Issue 2, June 1986, Pages 327-334
    【作者】J. R. Anderson, T. Mole and V. Christov
    【文题】Mechanism of some conversions over ZSM-5 catalyst
    【期刊名,年份,卷(期),起止页码】Journal of Catalysis, Volume 61, Issue 2, February 1980, Pages 477-484
    【作者】Herman Pines
    【文题】Comments on the interpretation of the mechanism of aromatic hydrocarbon participation in the production of hydrocarbons from methanol over ZSM-5 zeolite
    【期刊名,年份,卷(期),起止页码】Journal of Catalysis, Volume 93, Issue 1, May 1985, Pages 205-206
    【作者】N. Y. Chen
    【文题】Reactions of mixtures of toluene and methanol over ZSM-5
    【期刊名,年份,卷(期),起止页码】Journal of Catalysis, Volume 114, Issue 1, November 1988, Pages 17-22
    【作者】Tom Mole, Judith A. Whiteside and Duncan Seddon
    【文题】Aromatic co-catalysis of methanol conversion over zeolite catalysts
    【期刊名,年份,卷(期),起止页码】Journal of Catalysis, Volume 82, Issue 2, August 1983, Pages 261-266
    【作者】Hirofumi Itoh, Carmela V. Hidalgo, Tadashi Hattori, Miki Niwa and Yuichi Murakami
    【文题】Role of acid property of various zeolites in the methanol conversion to hydrocarbons
    【期刊名,年份,卷(期),起止页码】Journal of Catalysis, Volume 85, Issue 2, February 1984, Pages 521-526
    【作者】Desmond V. Dass, R. Wayne Martin and Allan L. Odell
    【文题】Studies on the conversion of methanol and other small molecules over H-ZSM-5: Yield studies and the use of 3H NMR in a reexamination of routes to ethylene production
    【期刊名,年份,卷(期),起止页码】Journal of Catalysis, Volume 108, Issue 1, November 1987, Pages 153-160
    【作者】J. R. Anderson, K. Foger, T. Mole, R. A. Rajadhyaksha and J. V. Sanders
    【文题】Reactions on ZSM-5-type zeolite catalysts
    【期刊名,年份,卷(期),起止页码】Journal of Catalysis, Volume 58, Issue 1, 15 June 1979, Pages 114-130
  • 该帖子已被管理者-设置为精华,下面是奖励记录:
  • 该帖子已被版主-海之巅加8积分,加2经验;加分理由:应助
  • 该帖子已被管理者-设置为精华,下面是奖励记录:加5积分,加5声望
  • 该帖子已被版主-海之巅加4积分,加2经验;加分理由:应助
  • fengxuezhang200
    第7楼2008/01/19
    非常感谢panyb15715),以上文章以下载,第10,12,15篇我托同学找到了,还有剩下的数篇,还烦请大家帮忙了。
    10 Conversion of methanol to ethylene over ZSM-5 zeolite: A reexamination of the oxonium-ylide hypothesis, using 13carbon- and deuterium-labeled feeds
    12 Mechanism of some conversions over ZSM-5 catalyst
    15 Studies on the conversion of methanol and other small molecules over H-ZSM-5: Yield studies and the use of 3H NMR in a reexamination of routes to ethylene production
  • fengxuezhang200
    第8楼2008/01/19
    【作者】Herman Pines
    【作者】N. Y. Chen
    以上三篇也以找到,剩下的几篇就期待着大家的回复了。
  • fengxuezhang200
    第9楼2008/01/19
    3 One- and two-component diffusion in zeolite ZSM-5 II. Experimental.Journal of Catalysis, Volume 126, Issue 1, November 1990, Pages 147-172 【作者】Waqar R. Qureshi and James Wei
    4 Formation of aromatic hydrocarbons during conversion of methanol. Petroleum Chemistry U.S.S.R., Volume 27, Issue 1, 1987, Pages 56-62
    6 Alkylation of toluene with methanol III: Para-selectivity on modified ZSM-5 zeolites. Zeolites, Volume 7, Issue 5, September 1987, Pages 408-411 【作者】S. Cavallaro, L. Pino, P. Tsiakaras, N. Giordano and B. S. Rao
    7 Bifunctional catalysis in syngas conversions. Catalysis Today, Volume 6, Issue 3, January 1990, Pages 207-234.【作者】V. Udaya, S. Rao and Robert J. Gormley
    8 On the H-ZSM-5 catalyzed formation of ethylene from methanol or higher olefins. Journal of Catalysis, Volume 99, Issue 1, May 1986, Pages 111-116【作者】R. M. Dessau
    11 The mechanism of aromatic transalkylation in ZSM-5. Journal of Catalysis, Volume 99, Issue 2, June 1986, Pages 327-334【作者】Don S. Santili
    16 Role of acid property of various zeolites in the methanol conversion to hydrocarbons. Journal of Catalysis, Volume 85, Issue 2, February 1984, Pages 521-526 【作者】Hirofumi Itoh, Carmela V. Hidalgo, Tadashi Hattori, Miki Niwa and Yuichi Murakami
    还剩以上几篇了,我做了整理。期待大家的帮助。
