1.AU Huggins, RA TI Lithium alloy negative electrodes SO JOURNAL OF POWER SOURCES PY 1999,82,13-19
2.AU Graetz, J;Ahn, CC;Yazami, R;Fultz, B TI Nanocrystalline and thin film germanium electrodes with high lithium capacity and high rate capabilities SO JOURNAL OF THE ELECTROCHEMICAL SOCIETY PY 2004,151,A698-A702
3.AU Kasavajjula, U;Wang, CS;Appleby, AJ;AF Kasavajjula, Uday; Wang Chunsheng;Appleby, A. John TI Nano- and bulk-silicon-based insertion anodes for lithium-ion secondary cells SO JOURNAL OF POWER SOURCES PY 2007,163, 1003-1039
4.TI Synthesis and optimization of nanoparticle Ge confined in a carbon matrix for lithium battery anode material AU Lee, H Kim, H Doo, SG Cho, J SO JOURNAL OF THE ELECTROCHEMICAL SOCIETY 2007,154,A343-A346
5.TI Nanocrystalline and thin film germanium electrodes with high lithium capacity and high rate capabilities AU Graetz, J Ahn, CC Yazami, R Fultz, B SO JOURNAL OF THE ELECTROCHEMICAL SOCIETY 2004,151, A698-A702
6.TI Interaction of diatomic germanium with lithium atoms: Electronic structure and stability AU Gopakumar, G Lievens, P Nguyen, MT SO JOURNAL OF CHEMICAL PHYSICS 2006,124,
7.TI First-principles study of lithium adsorption on Si(100)2 x 1 and Ge(100)2 x 1 surface at 1.0 monolayer coverage AU Wang, ZG Zu, XT Nie, JL Xiao, HY SO CHEMICAL PHYSICS 2006,325,525-530
8.TI Synthesis and characterization of SnO2-polypyrrole composite for lithium-ion battery AU Yuan, L Wang, J Chew, SY Chen, J Guo, ZP Zhao, L Konstantinov, K Liu, HK SO JOURNAL OF POWER SOURCES 2007, 174,1183-1187
