阳线
第1楼2008/05/31
ASTM A 663标准内没有图纸的。
ASTM A 663/A 663M-89(Reapproved 2000) Standard Specification for Steel Bars, Carbon, Merchant Quality, Mechanical PropertiesASTM A 663/A 663M-89(Reapproved 2000) Standard Specification for Steel Bars, Carbon, Merchant Quality, Mechanical Properties
阳线
第2楼2008/06/01
垫圈的标准中有图。
ASTM F 436M-03 Standard Specification for Hardened Steel Washers [Metric]ASTM F 436M-03 Standard Specification for Hardened Steel Washers (Metric)
ASTM F 436-03 Standard Specification for Hardened Steel WashersASTM F 436-03 Standard Specification for Hardened Steel Washers
阳线
第3楼2008/06/01
螺栓和接头的标准也没有图。
ASTM A 490M-04 Standard Specification for High-Strength Steel Blots, Classes 10.9 and 10.9.3, for Structural Steel Joints [Metric]ASTM A 490M-04 Standard Specification for High-Strength Steel Blots, Classes 10.9 and 10.9.3, for Structural Steel Joints (Metric)
合金钢、热处理的螺栓标准也没有图。
ASTM A 490-04 Standard Specification for Structural Blots, Alloy Steel, Heat Treated, 150 ksi Minimum Tensile StrengthASTM A 490-04 Standard Specification for Structural Blots, Alloy Steel, Heat Treated, 150 ksi Minimum Tensile Strength
