1. Facile transformation of nanofibrillar polymer aerogel to carbon nanorods catalyzed by platinum nanoparticles Nguyen Dang Luong, Youngkwan Lee and Jae-Do Nam J. Mater. Chem., 2008, 18, 4254 - 4259 http://www.rsc.org/Publishing/Journals/JM/article.asp?doi=b805031g 2. Morphology Change of Calcium Carbonate in the Presence of Polynucleotides Philip S. Lukeman, Mary L. Stevenson, and Nadrian C. Seeman Cryst. Growth Des., 8 (4), 1200–1202, 2008. 10.1021/cg700656r http://pubs.acs.org/cgi-bin/abstract.cgi/cgdefu/2008/8/i04/abs/cg700656r.html 3. Rapid room-temperature synthesis of silver nanoplates with tunable in-plane surface plasmon resonance from visible to near-IR Zongwei Cao, Hongbing Fu, Longtian Kang, Liwei Huang, Tianyou Zhai, Ying Ma and Jiannian Yao J. Mater. Chem., 2008, 18, 2673 - 2678 http://www.rsc.org/Publishing/Journals/JM/article.asp?doi=b800691a 4. Large-Scale Fabrication of Pr3+ Doped or Undoped Nanosized ATiO3 (A = Ca, Sr, Ba) with Different Shapes via a Facile Solvothermal Technique Xianmin Zhang, Jiahua Zhang, Ye Jin, Haifeng Zhao, and Xiao-jun Wang Cryst. Growth Des., 8 (3), 779–781, 2008. http://pubs.acs.org/cgi-bin/abstract.cgi/cgdefu/2008/8/i03/abs/cg701023x.html 5. Singular MoS2, SiO2 and Si nanostructures—synthesis by solar ablation Jeffrey M. Gordon, Eugene A. Katz, Daniel Feuermann, Ana Albu-Yaron, Moshe Levy and Reshef Tenne J. Mater. Chem., 2008, 18, 458 - 462, DOI: 10.1039/b714108d http://www.rsc.org/Publishing/Journals/JM/article.asp?doi=b714108d 6. Double Parallel Twinning on Cubic Crystals Angel Millan Cryst. Growth Des., 8 (2), 407–411, 2008. http://pubs.acs.org/cgi-bin/abstract.cgi/cgdefu/2008/8/i02/abs/cg060481j.html 7. Fabrication of electrically anisotropic agarose gels by dielectrophoretic assembly and encapsulation of silver nanowires William R. Small and Vesselin N. Paunov J. Mater. Chem., 2008, 18, 2082 - 2084 http://www.rsc.org/Publishing/Journals/JM/article.asp?doi=b802272k 8. Viral capsids as templates for the production of monodisperse Prussian blue nanoparticles Andrés de la Escosura, Martijn Verwegen, Friso D. Sikkema, Marta Comellas-Aragonès, Andrei Kirilyuk, Theo Rasing, Roeland J. M. Nolte and Jeroen J. L. M. Cornelissen Chem. Commun., 2008, 1542 http://www.rsc.org/Publishing/Journals/CC/article.asp?doi=b800936h
