海啸
第9楼2008/11/21
我下了,也安装了是 WIN95的,同样是也出现上述的提示说需要出入光盘什么的,
求助啊。
问题解决,但是感觉不是很好用,看来还要再试试
======reademe2=============================================================
about how to find the database of diagram
Now here is the tricky part of the installation:
Copy the \Diagrams\ directory to the folder where PED
is installed (e.g. C:\PEDv21\). Go to your win directory
(system directory,e.g. windows or winnt)
and create/edit the file PEDv21.ini (this file contains the path to the diagrams; preferable not a LFN).
The PEDv21.ini file should have this content:
[PED Database]
Path = "C:\PEDv21\"
DiagramPath = "C:\PEDv21\Diagrams\"
NOTE: If your install folder is not C:\PEDv21\ then you have to adjust the above information accordingly.
