movieaz用户
第2楼2008/10/21
谢谢!标准有了更新,需要的赶快下载!
ASTM
ASTM B 487-85
Standard Test Method for Measurement of Metal and Oxide Coating Thickness by Microscopical Examination of a Cross Section
ASTM A247-67 (Reapproved 1998) Standard test method for evaluating the microstructure of graphite in iron castings
ASTM A892-88 (Reapproved 2001) Standard guide for defining and rating the microstructure of high carbon bearing steels
ASTM B657-92 (Reapproved 2000) Standard test method for metallographic determination of microstructure in cemented tungsten carbides
ASTM B665-03 Standard guide for metallographic sample preparation of cemented tungsten carbides
ASTM E3-01 Standard practice for preparation of metallographic specimens
ASTM E7-03 Standard terminology relating to metallography
ASTM E8-04 Standard Test Methods for Tension Testing of Metallic Materials
ASTM E112-96 Standard test methods for determining average grain size
ASTM E930-99 Standard test methods for estimating the largest grain observed in a metallographic section (ala grain size)
ASTM E1268-01 Standard practice for assessing the degree of banding or orientation of microstructures
ASTM E1351-01 Standard practice for production and evaluation of field metallographic replicas
ASTM E1558-99 Standard guide for electrolytic polishing of metallographic specimens
ASTM E2014-99 Standard guide on metallographic laboratory safety
GB
GB/T 10561-89 钢中非金属夹杂物含量的测定标准评级图显微检验法
GB/T 10561-2005 钢中非金属夹杂物含量的测定标准评级图显微检验法
GB/T 1979-2001 结构钢低倍组织缺陷评级图
GB/T 6394-2002 金属平均晶粒度测定方法
GB/T 6394-2002 系列图 I(无孪晶晶粒++浅腐蚀100×)
GB/T 6394-2002 系列图Ⅱ(有孪晶晶粒++浅腐蚀+100×)
GB/T 6394-2002 系列图Ⅲ(有孪晶晶粒+深腐蚀75×)
GB/T 6394-2002 系列图Ⅳ(钢中奥氏体晶粒++渗碳法100×)
GB 224-1987 钢的脱碳层深度测定法
GB 226-1991 钢的低倍组织及缺陷酸蚀检验法
GB 2828-1987 逐批检查记数抽样程序及抽样表
GB 4236-1984 钢的硫印检验方法
GB 16840.4-1997 电气火灾原因技术鉴定方法 第4部分:金相法
GB/T 9450-2005 钢件渗碳淬火硬化层深度的测定和校核
GB/T 13298-1991 金属显微组织检验方法
GB/T 18876.1-2002 应用自动图像分析测定钢和其他金属中金相组织、夹杂物含量和级别的标准试验方法 第1部分
GB/T 4340.1-1999 金属维氏硬度 第一部分:试验方法
GB/T 14999.4-94 高温合金显微组织试验方法
GB/T 230.1-2004 金属洛氏硬度试验 第 1 部分: 试验方法 ( A, B, C, D, E, F, G, H, K, N, T标尺)
GB/T 231.1-2002 金属布氏硬度试验 第 1 部分: 试验方法
GB/T 3488-1983 硬质合金 显微组织的金相测定
GB/T 3489-1983 硬质合金 孔隙度和非化合碳的金相测定
GB/T 4194-1984 钨丝蠕变试验,高温处理及金相检查方法
GB/T 5617-1985 钢的感应淬火或火焰淬火后有效硬化层深度的测定
GB/T 6401-1986 铁素体奥氏体型双相不锈钢中α-相面积含量金相测定法
GB/T 7216-1987 灰铸铁金相
GB/T 8493-1987 一般工程用铸造碳钢金相
GB/T 8755-1988 钛及钛合金术语金相图谱
GB/T 9441-1988 球墨铸铁金相检验
GB/T 9450-1988 钢件渗碳淬火有效硬化层深度的测定和校核
GB/T 9451-1988 钢件薄表面总硬化层深度或有效硬化层深度的测定
GB/T 11809-1998 压水堆核燃料棒焊缝金相检验
GB/T 13305-1991 奥氏体不锈钢中α--相面积含量金相测定法
GB/T 13320-1991 钢质模锻件 金相组织评级图及评定方法
GB/T 13925-1992 铸造高锰钠金相
GB/T 17455-1998 无损检测 表面检查的金相复制件技术
GB 1814-1979 钢材断口检验方法
GB 2971-1982 碳素钢和低合金钢断口检验方法
GB/T 7998-2005 铝合金晶间腐蚀测定方法
GB/T 1298-2008 碳素工具钢
GB/T 1299-2000 合金工具钢
GB/T 1954-1980 铬镍奥氏体不锈钢焊缝铁素体含量测量方法
GB/T 3086-1982 高碳铬不锈轴承钢技术条件
GB/T 3246.1-2000 变形铝及铝合金制品显微组织检验方法
GB/T 3246.2-2000 变形铝及铝合金制品低倍组织检验方法
GB/T 3508-1983 内燃机铸造铝活塞金相检验标准
GB/T 4194-1984 钨丝蠕变试验、高温处理及金相检查方法
GB/T 4197-1984 钨钼及其合金的烧结坯条、棒材晶粒度测试方法
GB/T 4296-2004 变形镁合金显微组织检验方法
GB/T 4297-2004 变形镁合金低倍组织检验方法
GB/T 4335-1984 低碳钢冷轧薄板铁素体晶粒度测定法
GB/T 4342-1991 金属显微维氏硬度试验方法
GB/T 4462-1984 高速工具钢大块碳化物评级图
GB/T 4677.6-1984 金属和氧化覆盖层厚度测试方法 截面金相法
GB/T 5168-1985 两相钛合金高低倍组织检验方法
GB/T 5594.8-1985 电子元器件结构陶瓷材料性能测试方法 显微结构的测定
GB/T 5617-2005 钢的感应淬火或火焰淬火后有效硬化层深度的测定
GB/T 5680-1998 高锰钢铸件
GB/T 5929-1986 轻工产品金属镀层和化学处理层的厚度测试方法 金相显微镜法
GB/T 6462-2005 金属和氧化物覆盖层 厚度测量 显微镜法
GB/T 6463-2005 金属和其它无机覆盖层厚度测量方法评述
GB/T 6846-1986 确定暗室照明安全时间的方法
GB/T 8014.1-2005 铝及铝合金阳极氧化 氧化膜厚度的测量方法 第1部分测量原则
GB/T 8014.2-2005 铝及铝合金阳极氧化 氧化膜厚度的测量方法 第2部分质量损失法
GB/T 8014.3-2005 铝及铝合金阳极氧化 氧化膜厚度的测量方法 第3部分分光束显微镜法
GB/T 8756-1988 锗晶体缺陷图谱
GB/T 8760-2006 砷化镓单晶位错密度的测量方法
GB/T 9095-1988 烧结铁基材料 渗碳或碳氮共渗硬化层深度的测定
GB/T 9451-2005 钢件薄表面总硬化层深度或有效硬化层深度的测定
GB/T 9790-1988 金属覆盖层及其他有关覆盖层 维氏和努氏显微硬度试验
GB/T 10849-1989 铸造铝硅合金变质
GB/T 10850-1989 铸造铝硅合金过烧
GB/T 10851-1989 铸造铝合金针孔
GB/T 10852-1989 铸造铝铜合金晶粒度
GB/T 11250.1-1989 复合金属覆层厚度的测定 金相法
GB/T 11354-2005 钢铁零件 渗氮层深度测定和金相组织检验
GB/T 13320-2007 钢质模锻件 金相组织评级图及评定方法
GB/T 14999.1-1994 高温合金棒材纵向低倍组织酸浸试验法
GB/T 14999.2-1994 高温合金横向低倍组织酸浸试验法
GB/T 14999.3-1994 高温合金棒材纵向断口试验法
GB/T 14999.4-1994 高温合金显微组织试验法
GB/T 14999.5-1994 高温合金低倍、高倍组织标准评级图谱
GB/T 15749-1995 定量金相手工测定方法
GB/T 18876.1-2002 应用自动图像分析测定钢和其他金属中金相组织、夹杂物含量和级别的标准试验方法 第1部分钢和其他金属中夹杂物或第二相组织含量的图像分析与体视学测定
GB/T 18876.2-2006 应用自动图像分析测定钢和其它金属中金相组织、夹杂物含量和级别的标准试验方法 第2部分:钢中夹杂物级别的图像分析与体视学测定
GB/T 13299-1991 金相组织评级图及评定方法
