Software Review of Origin 8 R. Alan May and Keith J. Stevenson Publication Date (Web): December 29, 2008 (Computer Software Review) DOI: 10.1021/ja809638x Abstract • Full Text HTML • Hi-Res PDF[55K] • PDF w/ Links[55K]
ZnO-Templated Synthesis of Wurtzite-Type ZnS and ZnSe Nanoparticles Farah Dawood and Raymond E. Schaak Publication Date (Web): December 29, 2008 (Communication) DOI: 10.1021/ja808455u Abstract | Supporting Info • Full Text HTML • Hi-Res PDF[463K] • PDF w/ Links[182K]
Copper−Indium Sulfide Hollow Nanospheres Synthesized by a Facile Solution-Chemical Method Aiyu Zhang, Qian Ma, Mengkai Lu, Guangwei Yu, Yuanyuan Zhou and Zifeng Qiu Crystal Growth & Design, 2008, 8 (7), pp 2402–2405 Publication Date (Web): May 28, 2008 (Article) DOI: 10.1021/cg701257x Abstract | Supporting Info • Full Text HTML • Hi-Res PDF[806K] • PDF w/ Links[256K]
Chemistry of Metal Thio- and Selenocarboxylates: Precursors for Metal Sulfide/Selenide Materials, Thin Films, and Nanocrystals Jagadese J. Vittal and Meng Tack Ng Acc. Chem. Res., 2006, 39 (11), pp 869–877 Publication Date (Web): October 13, 2006 (Article) DOI: 10.1021/ar050224s Abstract • Full Text HTML • Hi-Res PDF[438K]
Ternary I−III−VI Quantum Dots Luminescent in the Red to Near-Infrared Peter M. Allen and Moungi G. Bawendi J. Am. Chem. Soc., 2008, 130 (29), pp 9240–9241 Publication Date (Web): June 27, 2008 (Communication) DOI: 10.1021/ja8036349 Abstract | Supporting Info • Full Text HTML • Hi-Res PDF[441K] • PDF w/ Links[149K]
Deposition of CuInS2 Thin Films Using Copper- and Indium/Sulfide-Containing Precursors through a Two-Stage MOCVD Method Seung Soo Lee, Kook Won Seo, Jong Pil Park, Sin Kyu Kim, and Il-Wun Shim Inorg. Chem., 2007, 46 (3), pp 1013–1017 Publication Date (Web): December 30, 2006 (Article) DOI: 10.1021/ic061445c Abstract • Full Text HTML • Hi-Res PDF[159K]
Synthesis of Colloidal CuGaSe2, CuInSe2, and Cu(InGa)Se2 Nanoparticles Jiang Tang, Sean Hinds, Shana O. Kelley and Edward H. Sargent Chem. Mater., 2008, 20 (22), pp 6906–6910 Publication Date (Web): October 28, 2008 (Article) Abstract | Supporting Info • Full Text HTML • Hi-Res PDF[786K] • PDF w/ Links[239K]
Synthesis of CuInS2, CuInSe2, and Cu(InxGa1-x)Se2 (CIGS) Nanocrystal “Inks” for Printable Photovoltaics Matthew G. Panthani, Vahid Akhavan, Brian Goodfellow, Johanna P. Schmidtke, Lawrence Dunn, Ananth Dodabalapur, Paul F. Barbara and Brian A. Korgel J. Am. Chem. Soc., 2008, 130 (49), pp 16770–16777 Publication Date (Web): November 17, 2008 (Article) DOI: 10.1021/ja805845q Abstract | Supporting Info • Full Text HTML • Hi-Res PDF[3126K] • PDF w/ Links[566K]
Photocatalytic H2 Evolution under Visible-Light Irradiation over Band-Structure-Controlled (CuIn)xZn2(1-x)S2 Solid Solutions Issei Tsuji, Hideki Kato, Hisayoshi Kobayashi, and Akihiko Kudo J. Phys. Chem. B, 2005, 109 (15), pp 7323–7329 Publication Date (Web): March 19, 2005 (Article) DOI: 10.1021/jp044722e Abstract • Full Text HTML • Hi-Res PDF[350K]
Nanocrystalline Chalcopyrite Materials (CuInS2 and CuInSe2) via Low-Temperature Pyrolysis of Molecular Single-Source Precursors Stephanie L. Castro, Sheila G. Bailey, Ryne P. Raffaelle, Kulbinder K. Banger, and Aloysius F. Hepp Chem. Mater., 2003, 15 (16), pp 3142–3147 Publication Date (Web): June 27, 2003 (Article) DOI: 10.1021/cm034161o Abstract • Full Text HTML • Hi-Res PDF[296K]
