20 Henry VM. 2002. Association of hydrophobic organic contaminants with soluble organic matter : Evaluation of the database of Kdoc values. A dv Envi ron Res ,6 : 577~593
30 Lee DY, Farmer WJ . 1989. Dissolved organic matter interaction with napropamide and four other nonionic pesticides. J Environ Qual ,18 :468~474 http://jeq.scijournals.org/cgi/reprint/18/4/468
37 Maxin CR , KÊgel-Knaber I. 1995. Partitioning of polycyclic aromatic hydrocarbons (PAH) to water-soluble soil organic matter. Eur J Soil Sci ,46 :193~20
39 McCarthy J F ,Roberson L E ,Burrus LW. 1989. Association of benzo (a) pyrene with dissolved organic matter : Prediction of dome from structural and chemical properties of the organic matter. Chemosphere ,19 : 1911~1920
50 Senesi NC ,Testini J ,Miano TM. 1987. Interaction mechanisms between humic acids of different origin and nature and electron donor herbicides : A comparative IR and ESR study. Org Geochem ,11 :25~30
52 Sposito G,Martin2Neto L , Yang A. 1996. Atrazine complication by soil humic acids. J Environ Qual ,25 :1203~1209 http://jeq.scijournals.org/cgi/reprint/25/6/1203
46 Raber B , KÊgel-Knaber I. 1997. Influence of origin and properties of dissolved organic matter on the partition of polycyclic aromatic hydrocarbons. Eur J Soil Sci ,29 :906~916
