第3楼2005/06/10
如果你指的是仪器上的功能,那么它们的区别如下:
Chronoamperometry:In Chronoamperometry (CA), potential is stepped from Init E toward either High E or Low E depending on the Init P/N. The potential will then step back. The following diagram shows the potential waveform applied as the function of time. The current is recorded as the function of time.
Amperometric i-t Curve:In Amperometric i-t Curve (i-t), a constant potential is applied and the current is recorded as the function of time. The following diagram shows the potential waveform applied as the function of time and the sample scheme.
简单的说,一个是恒电压的,一个是加脉冲电压的。
第5楼2007/03/14
在哪可以找到具体的有关资料呢?
