1 G. Ertl Oscillatory Catalytic Reactions at Single-Crystal Surfaces Advances in Catalysis, Volume 37, Pages 213-277 (1990)
2 You-Chang Xie, You-Qi Tang Spontaneous Monolayer Dispersion of Oxides and Salts onto Surfaces of Supports: Applications to Heterogeneous Catalysis Advances in Catalysis, Volume 37, Pages 1-43 (1990)
3 Luis G. Tejuca, José Luis G. Fierro, Juan M.D. Tascón Structure and Reactivity of Perovskite-Type Oxides Advances in Catalysis, Volume 36, Pages 237-328 (1989)
4 Gary L. Haller, Daniel E. Resasco Metal–Support Interaction: Group VIII Metals and Reducible Oxides Advances in Catalysis, Volume 36, Pages 173-235 (1989)
5 Michel Che, Carroll O. Bennett The Influence of Particle Size on the Catalytic Properties of Supported Metals Advances in Catalysis, Volume 36, Pages 55-172 (1989)
6 R.A. Van Santen, H.P.C.E. Kuipers The Mechanism of Ethylene Epoxidation Advances in Catalysis, Volume 35, Pages 265-321 (1987)
7 Yasuhiro Iwasawa Chemical Design Surfaces for Active Solid Catalysts Advances in Catalysis, Volume 35, Pages 187-264 (1987)
8 Daniel J. Driscoll, Kenneth D. Campbell, Jack H. Lunsford Surface-Generated Gas-Phase Radicals: Formation, Detection, and Role in Catalysis Advances in Catalysis, Volume 35, Pages 139-186 (1987)
9 Jan C.J. Bart, Gilberto Vlaic Extended X-Ray Absorption Fine Structure Studies in Catalysis Advances in Catalysis, Volume 35, Pages 1-138 (1987)
