謝謝指點。 但我看標準上 EN 14362 說 “If the amines are detected by one chromatographic method, then confirmation shall be made using one or more alternative methods.”
sin2008发表:謝謝指點。 但我看標準上 EN 14362 說 “If the amines are detected by one chromatographic method, then confirmation shall be made using one or more alternative methods.”
請問這里的 alternative methods 就是你說的那些方法嗎?但好像不是和色譜法等同的吧?
