注意到这些CV图电阻很大,以至于电位标度几乎没有意义,而且两个样品也没有可比性。存在一个巨大的IR降(欧姆电位损失)没有补偿或校正,因此曲线图中显示的很多电压并不是界面电位。
star_sss 发表:做的是钛合金的循环伏安,从-1V到+8V
别人给的意见,不知是什么意思?
Caution with these CVs the resistance is so large that the potential scale is hardly meaningful and likely not comparable for the two samples. There is a huge IR drop (ohmic potential loss) that has not been compensated or corrected for, so the interfacial potentials are nothing like the many Volts appearing in the plots?
