【分享】ICP氟石的元素分析
ICP光谱
  • 英文资料:
    Introduction
    The elelmental analysis of zeolites for their major and minor components requires a sample preparation approach that will dissolve a wide variety of elements without volatilization or precipitation losses. The first of the two main approaches taken by the analytical community has been to perform a fusion with a mixture of lithium tetraborate / lithium carbonate followed by dissolution of the fuseate with dilute nitric acid. The second approach is to perform a digestion of the sample with aqua regia followed by dissolution in cold hydrofluoric acid (< 5°C) and chelation of the excess HF with boric acid.
    Both preparations are followed by measurement using inductively coupled plasma emission spectroscopy. (ICPES). These procedures, which are state-of-the-art for quantitative zeolites elemental analysis, each required 1+ hours of sample preparation time and suffer from measurement problems associated with high solids containing solutions, such as torch and nebulizer fouling, high dilution factors, high Si blanks, and poor detection limits (approximately 100 ppm).
    These notes describe a procedure for the elemental analysis of zeolites that has reduced the sample preparation down to the time it takes to weigh the sample, add reagents, and shake. It has also eliminated the measurement problems associated with solutions containing high solids.
  • 该帖子已被版主-lilongfei14加2积分,加2经验;加分理由:谢谢资料分享
  • 牛爸爸虎儿子
    第1楼2010/03/14
    茫然中。。。楼主是上传资料的也是英文的吗?
  • lilongfei14
    第3楼2010/03/18
    如果能翻译过来就更好了
  • Onway
    第4楼2010/03/18
    是英文资料! 有时候看英文资料更能把握知识点
  • lilongfei14
    第5楼2010/03/19
    juway(juway) 发表:是英文资料! 有时候看英文资料更能把握知识点
    但是有些专业术语很难翻译的。
