ASTM C1607--Standard test method for determination of microwave safe for reheating" for ceramicware 陶瓷器皿在微波炉中加热安全性标准测试方法
ASTM C1644--Standard test method for graphite furnace atomic absorption spectrometric determination of lead and cadmium extracted from ceramic foodware 用石墨原子反应堆吸收光谱法测定陶瓷餐具中铅镉溶出的标准试验方法
ASTM C368--Standard test method for impact resistance of ceramic tableware 陶瓷餐具抗冲击性的标准试验方法
ASTM C872--Standard test method for lead and cadmium release from porcelain enamel surfaces 从搪瓷表面析出铅及镉的试验方法
ASTM C539--Standard test method for linear thermal expansion of porcelain enamel and glaze frits and ceramic whiteware materials by interferometric method用干扰法测定搪瓷、釉瓷和白色陶瓷材料线性热膨胀的试验
ASTM C927--Standard test method for lead and cadmium extracted from the lip and rim area of glass tumblers externally decorated with ceramic glass enamels外表用陶瓷玻璃釉装饰的玻璃酒杯杯口及外缘析出铅和镉的试验方法
ASTM C735--Standard test method for acid resistance of ceramic decorations on returnable beer and beverage glass containers可反复使用的饮料瓶(玻璃容器)上陶瓷装饰耐酸性的标准试验方法
ASTM C676--Standard test method for detergent resistance ofceramic decorations on glass tableware玻璃餐具上陶瓷装饰耐洗涤性的标准试验方法
ASTM C675--Standard test method for alkali resistance of ceramiC decorations on returnable beverage glass containers可反复使用的饮料瓶(玻璃容器)上陶瓷装饰耐碱性的标准试验方法
