〓猪哥哥〓
第2楼2010/11/30
1. Wavelength of UV-Visible Detector (HPLC)— Deviations from the wavelengths
specified in the method are not permitted.
检测器设置的波长必须和方法上的一致
2. The procedure specified by the detector manufacturer, or another validated procedure,
is to be used to verify that error in the detector wavelength is, at most, ±3 nm.
采用检测器生产商验证程序或者其他有效(权威)的验证程序验证波长误差在正负3nm
