chengjingbao
第1楼2011/01/11
Too get rid of such situation, you should enter a new (lower) threshold value. To enter a new value just use the numerical keys on the keypad followed by enter key (E key). The value must be between 0 and 16,777,215 counts. The default value is normally just what the system needs and under normal conditions this value should not be changed.
要摆脱这种情况,你可以输入一个新的(较低)的界定值。要输入一个新值,你只需要使用键盘盘上的数字键,然后按E键确认。该值必须在0~16,777,215之间。该默认值通常应满足系统需要,且正常条件下不要改变。
poorlittle
第2楼2011/01/11
If (......, and......) then what?
Is there anything missing? Or "and" is a redundant?
