灰米奇
第1楼2011/03/18
好像只找到这些,楼主看看是不是链接中的
DIN 20022 1 ST/EN853 1 ST. Construction: This hose consists of an inner tube of oil-resistant synthetic rubber, a single wire braid
1,http://www.kingmaxrubber.com/CP3-1.HTML
DIN 20022 2 ST/EN853 2 ST. Construction: This hose consists of an inner tube of oil-resistant synthetic rubber, two wire braids
http://www.kingmaxrubber.com/cp4-1.html
DIN 20022 EN 853 1SN
http://sino-flex.com/2DIN_EN_Standard-1.htm
DIN 20022 EN 853 2SN
http://sino-flex.com/2DIN_EN_Standard-2.htm
DIN 20022 EN 857 1SC
http://sino-flex.com/2DIN_EN_Standard-3.htm
DIN 20022 EN 857 2SC
http://sino-flex.com/2DIN_EN_Standard-4.htm
