方法包括: NOAA_NST130.00 Capillary gas chromatography analysis for organic contaminates in marine sediments. NOAA_NST130.01 Organic contaminates in marine animal tissues by GC-FPD EPA150.1 pH in Water by Electrometric Method EPA150.2 pH in Water EPA1624 Volatile Organic Compounds by GC/MS EPA508A PCBs by GCECD EPA524.2 VOCs in Water Using GCMS EPA525.2 Organics in Water Using GCMS EPA526 SVOCs in Water by GCMS EPA528 Phenols in Water by GC/MS EPA550 PAHs in Water Using HPLC/UV/FL EPA550.1 PAHs in Water Using HPLC/UV/FL EPA551.1 Chlorinated Compounds in Water Using GC-ECD EPA8100 Polynuclear Aromatic Hydrocarbons in Water and Solid Samples by GC-FID EPA8141B Organophosphorus Compounds in Water, Soil, and Waste Samples by GC-NPD EPA8141B Organophosphorus Compounds in Water, Soil, and Waste Samples by GC-FPD 这是我自己平时收藏的,与大家分享了! 17种分析方法(英语)
