【分享】电容选型指南
物性测试综合讨论
  • 原始出处:http://www.radio-electronics.com/info/data/capacitor/capacitor_typ
    The table below gives and overview of the main characteristics of the various types of capacitor.
    Capacitor typesCapacitance rangeAccuracyTemperature stabilityLeakageComments & details
    Electrolytic 0.1 µF - ~1 F V poor V poor Poor Polarised capacitor - widely used in power supplies for smoothing, and bypass where accuracy, etc is not required.
    Ceramic 10 pF - 1 µF Variable Variable Average Exact performance of capacitor depends to a large extent on the ceramic used.
    Tantalum 0.1 µF - 500 µF Poor Poor Poor Polarised capacitor - very high capacitance density.
    Silver mica 1 pF - 3000 pF Good Good Good Rather expensive and large - not widely used these days except when small value accurate capacitors are needed.
    Polyester (Mylar) 0.001 µF - 50 µF Good Poor Good Inexpensive, and popular for non-demanding applications.
    Polystyrene 10 pF - 1 µF V good Good V good High quality, often used in filters and the like where accuracy is needed.
    Polycarbonate 100 pF - 20 µF V good V good Good Used in many high tolerance and hash environmental conditions. Supply now restricted.
    Polypropylene 100pF - 50 µF V good Good V good High performance and low dielectric absorption.
    Teflon 100 pF - 1 µF V good V v good V v good High performance - lowest dielectric absorption.
    Glass 10 pF - 1000 pF Good Good V good Excellent for very harsh environments while offering good stability. Very expensive.
    Porcelain 100 pF - 0.1 µF Good Good Good Good long term stability
    Vacuum and air 1 pF - 10 000 pF Often used as variable capacitors in transmitters as a result of their very high voltage capability.
  • 大陆
    第1楼2011/04/08
    不难看出,电容差异主要在于介质材料。
    电容密度最大的是电解电容,但是损耗大、精度低;
    损耗最低,最稳定,耐压性能最好的电容是真空电容,但电容很难做高;
    兼顾电容大小和最低损耗,最稳定性能的电容无疑是特富龙电容,不过一般市面上很难买到;
    市面上较容易买的特富龙电容的替代品,一般是聚丙烯电容。
  • 大陆
    第2楼2011/04/08
    世界上最优秀的电容、产商品牌型号(含网址)列举如下:
    产地 电容介质 耐压参数(DCV) 美国市场零售价 网址
    Audience/Auricap 美国 金属工艺聚丙烯 600 $14.76 www.auricap.com
    Audio Consulting 瑞士 油,薄膜和金属箔 1250 $65.00 www.audio-consulting.ch
    Audio Note/Silver 英国 聚酯和银箔 600 $155.80 www.audionote.co.uk
    Cardas/Golden Ratio 美国 金属工艺聚丙烯 600 $16.44 www.cardas.com
    Hovland/Musicap 美国 聚丙烯薄膜和金属箔 600 $11.52 www.hovlandcompany.com
    Jensen/Aluminum 丹麦 油浸纸和铝箔 400 $12.75 www.jensencapacitors.com
    Jensen/Copper 丹麦 油浸纸和铜箔 630 $19.00
    Jupiter 美国 蜂蜡纸和铝箔 600 $17.00 www.jupitercondenser.com
    Mundorf/Supreme
    Silver/Oil 德国 金属工艺聚丙烯 1200 $20.40 www.mundorf.com
    Mundorf/Supreme
    Silver/Gold 德国 金属工艺聚丙烯 1200 $32.90
    Mundorf/Supreme 德国 金属工艺聚丙烯 1200 $10.00
    North Creek Music/
    Crescendo 美国 聚丙烯薄膜和金属箔 800 $8.95 www.northcreekmusic.com
    REL/PPMT 美国 金属工艺聚丙烯 600 $8.09 www.capacitors.com
    REL/Exotica TFT 美国 特氟隆和锡箔 600 $42.38
    REL/Exotica PCU 美国 聚丙烯和铜箔 600 $30.32
    Solen/SM 法国 聚丙烯薄膜和锡箔 630 $3.95 www.solen.ca
    Solen/PPE 法国 金属工艺聚丙烯 630 $1.35 www.solen.ca
    TRT/Dynamicap 美国 金属工艺聚丙烯 425 $11.95 www.trt-wonder.com
    V-cap/TFTF 美国 特氟隆和锡箔 600 $49.99 www.v-cap.com
    Xicon 中国 金属工艺聚丙烯 630 $0.73 www.mouser.com/xicon
    Russian Military Surplus 前苏联 特氟隆和锡箔 500 $2-3 http://www.machmat.com/sales/capateflon.htm
  • yuduoling
    第5楼2011/04/08
    学习学习,多谢分享了
