poorlittle
第3楼2011/04/10
Information can be obtained by searching with Google using the keywords “straggler, outlier, statistics, definition”
For example :
http://www.astm.org/SNEWS/ND_2008/datapoints_nd08.html
Outliers are also known by other names: maverick, flier, straggler or aberrant
value. .... part of ASTM Committee E11 on Quality and Statistics. ...
http://www.nordicinnovation.net/nordtestfiler/tec482.pdf
Outlier: A member, of a set of values, which is inconsistent with the other members of
that set. The consistency can be tested using graphical or numerical techniques (see
sections 4.3 and 4.4).
Straggler: Similar to an outlier but with less inconsistency (see section 4.4 for criteria).
http://www.icp-forests.org/DocsQualLab/EvaluationSoilRingTests.pdf
Organisation and evaluation of future ring tests for Soil
Numerical outliers techniques. If test statistic > 1% critical value = outlier.
If test statistic > 5 % critical value = straggler ...
symmacros
第4楼2011/04/10
Please refer to the following information,
Extreme values,
stragglers and outliers
Extreme values are defined as observations
in a sample, so far separated in value from
the remainder as to suggest that they may
be from a different population, or the
result of an error in measurement (6).
Extreme values can also be subdivided into
stragglers, extreme values detected
between the 95% and 99% confidence
and outliers; extreme values at >
99% confidence level.
