序号:1 作者:Chandra S (Chandra, S.)1, Saleem H (Saleem, H.)2, Sebastian S (Sebastian, S.)3, Sundaraganesan N (Sundaraganesan, N.)1 题目:The spectroscopic (FT-IR, FT-Raman), NCA, first order hyperpolarizability, NBO analysis, HOMO and LUMO analysis of L-cysteine by ab inito HF and density functional method 期刊:SPECTROCHIMICA ACTA PART A-MOLECULAR AND BIOMOLECULAR SPECTROSCOPY 起止码:卷: 78 期: 5 页: 1515-1524
序号:2 作者:Ishkulova NR (Ishkulova, N. R.)1, Oparina LE (Oparina, L. E.)1, Kochetova LB (Kochetova, L. B.)1, Kustova TP (Kustova, T. P.)1, Kalinina NV (Kalinina, N. V.)1, Kuritsin LV (Kuritsin, L. V.)1 题目:Reactivity of alpha-amino acids in the N-acylation with benzoic acid esters in aqueous dioxane 期刊:RUSSIAN JOURNAL OF GENERAL CHEMISTRY 起止码:卷: 80 期: 5 页: 964-967
序号:3 作者:Ibrahim M (Ibrahim, Medhat)1,2, Mahmoud AA (Mahmoud, Abdel Aziz)1, Osman O (Osman, Osama)1, Refaat A (Refaat, Ahmed)1, El-Sayed ESM (El-Sayed, El-Sayed M.)3 题目:Molecular spectroscopic analysis of nano-chitosan blend as biosensor 期刊:SPECTROCHIMICA ACTA PART A-MOLECULAR AND BIOMOLECULAR SPECTROSCOPY 起止码:卷: 77 期: 4 页: 802-806 序号:4 作者:Gece G (Gece, G.)1, Bilgic S (Bilgic, S.)1, Turksen O (Turksen, O.)2 题目:Quantum chemical studies of some amino acids on the corrosion of cobalt in sulfuric acid solution 期刊:MATERIALS AND CORROSION-WERKSTOFFE UND KORROSION 起止码:卷: 61 期: 2 页: 141-146 出版年: FEB 2010 序号:5 作者:Ishkulova NR (Ishkulova, N. R.)1, Oparina LE (Oparina, L. E.)1, Kochetova LB (Kochetova, L. B.)1, Kustova TP (Kustova, T. P.)1, Kalinina NV (Kalinina, N. V.)1, Kuritsin LV (Kuritsin, L. V.)1 题目:Reactivity of alpha-amino acids in the N-acylation with benzoic acid esters in aqueous dioxane 期刊:RUSSIAN JOURNAL OF GENERAL CHEMISTRY 起止码:卷: 80 期: 5 页: 964-967 出版年: MAY 2010
