Current consultations | ||||||||
Substance identification | Proposing authority | Reason for proposing | Date of publication | Deadline for commenting | Link to the Annex XV report | Link to commenting form | ||
Substance name | EC number | CAS number | ||||||
Lead dipicrate | 229-335-2 | 6477-64-1 | ECHA 1 | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
Lead styphnate | 239-290-0 | 15245-44-0 | ECHA 1 | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
Lead diazide | 236-542-1 | 13424-46-9 | ECHA 1 | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
Phenolphthalein | 201-004-7 | 1977/9/8 | ECHA 1 | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
2,2'-dichloro-4,4'-methylenedianiline (MOCA) | 202-918-9 | 101-14-4 | ECHA 1 | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
N,N-dimethylacetamide (DMAC) | 204-826-4 | 127-19-5 | ECHA 1 | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
trilead diarsenate | 222-979-5 | 3687-31-8 | Norway | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
calcium arsenate | 231-904-5 | 7778-44-1 | Norway | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
arsenic acid | 231-901-9 | 7778-39-4 | Norway | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
bis(2-methoxyethyl) ether | 203-924-4 | 111-96-6 | Austria 2 | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
1,2-Dichloroethane | 203-458-1 | 107-06-2 | Slovakia | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
4-(1,1,3,3-tetramethylbutyl)phenol, (4-tert-Octylphenol) | 205-426-2 | 140-66-9 | Germany | equivalent concern | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
2-Methoxyaniline | 201-963-1 | 90-04-0 | Germany | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
o-Anisidine | ||||||||
Bis(2-methoxyethyl) phthalate | 204-212-6 | 117-82-8 | Germany | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
Formaldehyde, oligomeric reaction products with aniline (technical MDA) | 500-036-1 | 25214-70-4 | Germany | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
Zirconia Aluminosilicate Refractory Ceramic Fibres (Zr-RCF) | Germany | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] | ||
Aluminosilicate Refractory Ceramic Fibres (RCF) | Germany | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] | ||
Pentazinc chromate octahydroxide | 256-418-0 | 49663-84-5 | France | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
Potassium hydroxyoctaoxodizincatedichromate | 234-329-8 | 11103-86-9 | France | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments ] |
Dichromium tris(chromate) | 246-356-2 | 24613-89-6 | France | CMR | 29/08/2011 | 13/10/2011 | [ View ] | [ Give comments |
chinaboy1314521
第4楼2011/09/08
EU每半年公布2次SVHC,一般是6月和12份左右,所以大家逃避是不现实,应该勇敢面对啊:
各位应该长远打算,不要总是想的测试(最悲剧的是:无机化合物,是很难分析出来,目前的科技水平),应该建立一个化学物质数据库和体系,这样EU公布,你就一变应万变,刚开始很定痛苦,方向对了,总会有结果:
1. 任何化学品要求制造商提供SDS(指化学品制造商:色粉,胶水,塑胶,布,皮,纸,粘和剂,玻璃,油漆,油墨等).
2. 你可依据SDS统计化学物质数据库(物质名,CAS#,含量,分类),分类很重要,尤其是C.M.R物质,是一定通报的,没有商业机密的理由,这是义务,这是法律规定,难道三鹿奶粉加三聚氢胺是商业机密成分??? 3. 把SVHC以文件纳入公司物质管理目录清单,发行给各部门和供应商,并培训和宣导!必要的....保持更新,更重要。。。
4.依据掌握的资料可建立SVHC风险材料和SVHC物质风险目录。可分为高,中,低。为了节省成本,列出一个测试计划,重点测量高风险。没有必要全部测试,那样太浪费了,也不可取。因为SVHC大概1千多种。。。。。
启赞
第5楼2011/09/22
这才是正确的方向!
