求这篇文献是否已经被SCI网络版收录?
文献检索-互助
  • 求这篇文献是否已经被SCI网络版收录?
    【序号】:1
    【作者】:Santana, Frampton Franklin; Augusto, Pedro Esteves Duarte; and Cristianini, Marcelo
    【题名】:etermination of the Convective Heat Transfer Coefficient (h) in the Sterilization of Retortable Pouches
    【期刊】:International Journal of Food Engineering
    【年、卷、期、起止页码】:2011, 7, 1, Article 10,
    DOI: 10.2202/1556-3758.2157
  • 马踏飞燕
    第1楼2011/09/28
    说不上啊,你可以查查啊!
  • hstudent
    第2楼2011/09/28
    已收录
    Determination of the Convective Heat Transfer Coefficient (h) in the Sterilization of Retortable Pouches
    作者: Santana, FF (Santana, Frampton Franklin)1; Augusto, PED (Duarte Augusto, Pedro Esteves)1,2; Cristianini, M (Cristianini, Marcelo)1
    来源出版物: INTERNATIONAL JOURNAL OF FOOD ENGINEERING 卷: 7 期: 1 文献号: 10 DOI: 10.2202/1556-3758.2157 出版年: 2011
    被引频次: 1 (来自 Web of Science)
    引用的参考文献: 38 [ 查看 Related Records ] 引证关系图
    摘要: The present work has employed an optimization process among experimental temperatures and those obtained by finite elements analysis (FEA) for the determination of the convective heat transfer coefficient (h) during a stand up retortable pouch process in a steam-air retort. The process was divided in four periods, and the values obtained were: 828.7 W.m(-2).K(-1) (hh1, first portion of heating; come up time); 538.5 W.m(-2).K(-1) (hh2, second portion of heating; ball time); 1293.6 W.m(-2).K(-1) (hc(1), first phase of cooling); and 183.6 W.m(-2).K(-1) (hc(2), second phase of cooling). The results obtained were validated experimentally by meat product sterilization, presenting good correlation between experimental values and those obtained by the model. The values obtained contribute to the studies of heat transfer and thermal processes; besides, its values for pouches processes are scarce in the literature.
    文献类型: Article
    语种: English
    作者关键词: convective heat transfer coefficient (h); retortable pouch; sterilization; thermal process
    KeyWords Plus: COMPUTATIONAL FLUID-DYNAMICS; FOOD POUCHES; CANNED FOOD; CONTAINERS; PREDICTION; TIME
    通讯作者地址: Santana, FF (通讯作者),Univ Estadual Campinas, Sch Food Engn FEA, Campinas, SP, Brazil
    地址:
    1. Univ Estadual Campinas, Sch Food Engn FEA, Campinas, SP, Brazil
    2. Tech Sch Campinas COTUCA, Campinas, SP, Brazil
    电子邮件地址: frampton.santana@bol.com.br, pedro@cotuca.unicamp.br, olecram@fea.unicamp.br
    出版商: BERKELEY ELECTRONIC PRESS, 2809 TELEGRAPH AVENUE, STE 202, BERKELEY, CA 94705 USA
    JCR® 类别: Food Science & Technology
    学科类别: Food Science & Technology
    IDS 号: 715NQ
    ISSN: 1556-3758
  • 该帖子已被版主-灰米奇加2积分,加2经验;加分理由:参与应助
  • hstudent
    第3楼2011/09/28
    FN Thomson Reuters Web of Knowledge
    VR 1.0
    PT J
    AU Santana, FF
    Augusto, PED
    Cristianini, M
    AF Santana, Frampton Franklin
    TI Determination of the Convective Heat Transfer Coefficient (h) in the Sterilization of Retortable Pouches
    SO INTERNATIONAL JOURNAL OF FOOD ENGINEERING
    LA English
    DT Article
    DE convective heat transfer coefficient (h); retortable pouch; sterilization; thermal process
    ID COMPUTATIONAL FLUID-DYNAMICS; FOOD POUCHES; CANNED FOOD; CONTAINERS; PREDICTION; TIME
    AB The present work has employed an optimization process among experimental temperatures and those obtained by finite elements analysis (FEA) for the determination of the convective heat transfer coefficient (h) during a stand up retortable pouch process in a steam-air retort. The process was divided in four periods, and the values obtained were: 828.7 W.m(-2).K(-1) (hh1, first portion of heating; come up time); 538.5 W.m(-2).K(-1) (hh2, second portion of heating; ball time); 1293.6 W.m(-2).K(-1) (hc(1), first phase of cooling); and 183.6 W.m(-2).K(-1) (hc(2), second phase of cooling). The results obtained were validated experimentally by meat product sterilization, presenting good correlation between experimental values and those obtained by the model. The values obtained contribute to the studies of heat transfer and thermal processes; besides, its values for pouches processes are scarce in the literature.
    C1 [Santana, FF; Augusto, PED; Cristianini, M] Univ Estadual Campinas, Sch Food Engn FEA, Campinas, SP, Brazil
    [Augusto, PED] Tech Sch Campinas COTUCA, Campinas, SP, Brazil
    RP Santana, FF (reprint author), Univ Estadual Campinas, Sch Food Engn FEA, Campinas, SP, Brazil
    EM frampton.santana@bol.com.br pedro@cotuca.unicamp.br olecram@fea.unicamp.br
    NR 38
    TC 1
    Z9 1
    PU BERKELEY ELECTRONIC PRESS
    PI BERKELEY
    PA 2809 TELEGRAPH AVENUE, STE 202, BERKELEY, CA 94705 USA
    SN 1556-3758
    J9 INT J FOOD ENG
    JI Int. J. Food Eng.
    PY 2011
    VL 7
    IS 1
    AR 10
    DI 10.2202/1556-3758.2157
    PG 15
    WC Food Science & Technology
    SC Food Science & Technology
    GA 715NQ
    UT WOS:000286891600014
    ER
    EF
