【第四届原创】Application of GC/MS in Studies on Separation and Identification of Organic Species in Coals
  • allanyoung
    2011/10/30
厂商论坛
  • 原创性说明:
    色谱质谱联用技术被广泛应用在能源行业。相对于液相色谱质谱联用技术,气相色谱质谱联用技术(以下简称气质)能分析检测极性低的小分子物质。这是由其配置的电子轰击离子源的特性所决定的。煤是一种成分复杂的化石燃料和化工原料,其中富含分子极性较低的芳烃和脂肪族化合物,及两者联接的网状结构。利用电子轰击离子源的特性,加上气相色谱较高的分离性能,可以对煤中复杂的成分和结构做的较为精确的分析。在温和条件下,利用萃取等手段对煤中的有机质做族组分分离,继而用气质进行检测,获取煤的分子结构信息
    ,将为煤的高效洁净利用提供重要的理论基础和科学依据
    Abstract:
    The use of gas chromatography/mass spectrometry (GC/MS) in the investigation of coal structure and identification for composition of small molecules was reviewed. Macromolecules and small molecules coexist in coals. Understanding the role of small molecules is the fundamental for effective, clean and value-added utilization of coals. For coals after treatments (extraction, oxidation and liquefaction), small molecules can be extracted from the macromolecular network and analyzed using GC/MS. Various kinds of organic species were identified using GC/MS, which gave explanation for coal structure, mechanism of coal liquefaction and oxidation.
  • dahua1981
    第2楼2011/10/30
    楼主的内容还保密吗
  • allanyoung
    第3楼2011/11/01
    已上载了。
    yuduoling(yuduoling) 发表:原创作品呢?
