kylabs
第1楼2012/01/31
5-羟色胺没有找到,但是有色胺的LCMS检测方法可以参考,需要使用比较特殊的亲水柱来做。色胺比5-羟色胺更难保留,所以这个条件做5-羟色胺应该没有问题。
Column | Cogent Diamond Hydride™, 4µm, 100A | ||||||||||||||||
Catalog No. | 70000-15P-2 | ||||||||||||||||
Dimensions | 2.1 x 150 mm | ||||||||||||||||
Solvents | A: DI water + 0.1% ammonium formate pH 5.9 B: 90% acetonitrile/10% DI water w/ 0.1% ammonium formate pH 6 | ||||||||||||||||
Mobile Phase | Gradient t0 = 1.44 min
Flow Rate | 0.4 mL/min. | ||||||||||||||||
Sample | Mixture of 3 biogenic amines:
Detection | ESI � neg - Agilent 6210 MSD TOF mass spectrometer. |
