水中呋喃丹及草甘膦的检测除了柱后衍生还有别的方法吗
  • xiaokeke870614
    2012/01/30
  • 该帖子已被版主-蓝人加2积分,加2经验;加分理由:鼓励深入研究
  • kylabs
    第1楼2012/01/30
    草甘膦有一个非衍生的方法:
    Method Conditions
    ColumnCogent Diamond Hydride™, 4µm, 100A
    Catalog No.70000-15P-2
    Dimensions2.1 x 150 mm
    SolventsA: DI water + 5 mM ammonium acetate
    B: 90% acetonitrile/10% DI water/10 mM ammonium acetate
    Gradient0.0 min � 80.0%B
    1 .0 min 80%B
    1.1 min to 5%B
    5.0 min 5%B
    6.0 min to 80%B
    Post time5 min
    Flow rate0.5 mL/min.
    Sample PrepGlyphosate: 168.0067m/z (M - H)-
    Figure A: injection #1, RT = 3.365 min
    Figure B: injection #5, RT = 3.366 min
    Sample stock solution was purchased from Sigma (1000 mcg/mL). Sample
    for analysis was made by diluting the stock 1:100 in 30:70 solution A and B.
    DetectionESI � neg - Agilent 6210 MSD TOF mass spectrometer.
    Discussion
    A reliable method for the determination of glyphosate is presented. Analysis was performed using a Cogent Diamond Hydride™ HPLC column which provides very reproducible retention and fast equilibration even when a gradient analysis is used. The use of LC-MS detection allows avoiding time consuming derivatization of this compound which is lacking a chromophore for UV detection. The method shown, with ANP retention avoids derivatization, which is required when an ordinary C18 column is used.
  • tangtang
    第2楼2012/01/30
    Cogent Diamond Hydride这根柱子是不是比较特殊?
  • kylabs
    第3楼2012/01/30
    属于特殊的亲水柱,通常可以运行反反相(水系正相,ANP)模式对亲水化合产生保留。
    tangtang(tangtang) 发表:Cogent Diamond Hydride这根柱子是不是比较特殊?
  • xiaokeke870614
    第4楼2012/02/02
    请问这个方法是出自哪儿的呢?
    kylabs(kylabs) 发表:草甘膦有一个非衍生的方法:
    Method Conditions
    1 .0 min 80%B
    1.1 min to 5%B
    5.0 min 5%B
    6.0 min to 80%B
    Post time5 min
    Discussion
  • kylabs
    第5楼2012/02/02
    参见以下网址:
    http://www.microsolvtech.com/hplc/app_glyphosate.asp
  • 该帖子已被版主-有水有渝加2积分,加2经验;加分理由:感谢分享
