冰火女孩
第1楼2012/02/03
标准号是多少?或者标准的名称是什么??
zhanzhigur
第3楼2012/02/09
Toy regulations (SOR/2011-17)
关于化学部分简单的无法想象。
TOXICOLOGICAL HAZARDS
Specific toxic substances
22. A toy must not contain any of the following substances if they could, under reasonably foreseeable circumstances, become accessible to a child or, if they are used as a filling, could be released on breakage or leakage:
(a) carbon tetrachloride or any substance that contains it;
(b) methyl alcohol or any substance that contains more than 1% weight to volume of methyl alcohol;
(c) petroleum distillates or any substance that contains more than 10% weight to volume of petroleum distillates;
(d) benzene;
(e) turpentine or any substance that contains more than 10% weight to volume of turpentine;
(f) boric acid or salts of boric acid; or
(g) ethyl ether.
Specific substances in surface coatings
23. The surface coating material that is applied to a toy must not contain any of the following substances:
玩具上所用涂层必须不包含下列物质:
(a) more than 90 mg/kg of total lead;
超过90ppm的铅
(b) a compound of antimony, arsenic, cadmium, selenium or barium introduced as such if more than 0.1% of the compound dissolves in 5% hydrochloric acid after being stirred for 10 minutes at 20°C (68°F); or
在10%的HCl 20度中振荡10分钟后,超过0.1%的Sb,Se,Cd,As,Ba的化合物(以元素计)
(c) a compound of mercury introduced as such.
汞化合物(以汞计)
