luoxiandong
第3楼2012/03/29
Regulation: SOR/2010-298
Product scope should be:
1)Children's Toys (for children <14 years learning or play)
2)Child care article.(“child care article” means a product that is intended to facilitate the relaxation, sleep, hygiene, feeding, sucking or teething of a child under four years of age.)
Test part:
Accessible material only
Coating/plating/ fabric will not consider as barrier.
Test materials:
Vinyl (know as PVC)
Limit:
DEHP, DBP and BBP
The vinyl in a toy or child care article must contain not more than 1 000 mg/kg of di(2-ethylhexyl) phthalate (DEHP), dibutyl phthalate (DBP) or benzyl butyl phthalate (BBP) when tested in accordance with a method that conforms to good laboratory practices.
DINP, DIDP and DNOP
The vinyl in any part of a toy or child care article that can, in a reasonably foreseeable manner, be placed in the mouth of a child under four years of age must contain not more than 1 000 mg/kg of diisononyl phthalate (DINP), diisodecyl phthalate (DIDP) or di-n-octyl phthalate (DNOP) when tested in accordance with a method that conforms to good laboratory practices.
For more informations, you could use below links:
http://laws-lois.justice.gc.ca/eng/regulations/SOR-2010-298/index.html
zhanzhigur
第4楼2012/03/30
看了SOR/2010-298,有点疑惑,第二点“Test part”在法令的那个部分里有提及?我看了两遍,没有找到有表述“可接触”的字眼。谢谢。
luoxiandong
第6楼2012/04/05
Dear Zhanzhi,
Kindly refer to below links for more information(point 5, exemption):
http://www.gazette.gc.ca/rp-pr/p2/2010/2010-12-22/html/sor-dors297-eng.html
5. Exemption on the use of DEHP, DBP and BBP in inaccessible soft vinyl components (a stakeholder recommendation)
An additional option was identified by stakeholders following the pre-publication of the proposed Phthalates Regulations in the Canada Gazette, Part I, on June 20, 2009 (see www.hcsc.gc.ca/cps-spc/legislation/consultation/_2009phthalates-phtalates/ index-eng.php). Under this option, the restriction on DINP, DIDP and DNOP in the soft vinyl of children’s toys and child care articles that can foreseeably be placed in the mouth of a child under four years of age would be extended to DEHP, DBP and BBP, thereby exempting soft vinyl components of toys and child care articles that are not accessible (e.g. the vinyl coating on internal wires, or vinyl footpads on the bottom of crib legs) and, therefore, not a risk to children’s health. The government carefully considered this option, and remains of the view that Canada’s requirements for phthalates should be aligned with those of the United States and the European Union to be assured that young Canadian children are benefitting from at least the same level of protection as young children in the United States and the European Union.
