Phases 相
G1 | Dimethylpolysiloxane oil. | 二甲基聚硅氧烷油 |
G2 | Dimethylpolysiloxane gum. | 二甲基聚硅氧烷胶 |
G3 | 50% Phenyl-50% methylpolysiloxane. | 50%苯基-50%甲基聚硅氧烷 |
G4 | Diethylene glycol succinate polyester. | 聚丁二酸乙二醇酯 |
G5 | 3-Cyanopropylpolysiloxane. | 3-氰丙基聚氧硅烷 |
G6 | Trifluoropropylmethylpolysiloxane. | 三氟丙基甲基聚硅氧烷 |
G7 | 50% 3-Cyanopropyl-50% phenylmethylsilicone. | 50%-3-氰丙基-50%苯甲基硅氧烷 |
G8 | 80% Bis(3-cyanopropyl)-20% 3-cyanopropylphenylpoly- siloxane (percentages refer to molar substitution). | 80%双(3-氰基丙基)-20%3-氰丙基苯聚硅氧烷(百分比参见分子取代度) |
G9 | Methylvinylpolysiloxane. | 甲基乙烯基聚硅氧烷 |
G10 | Polyamide formed by reacting a C36 dicarboxylic acid with 1,3-di-4-piperidylpropane and piperidine in the respective mole ratios of 1.00:0.90:0.20. | 聚酰胺,由C36 二羧酸和1,3-二-4-哌啶基丙烷和哌啶以摩尔比1.00:0.90:0.20反应而得 |
G11 | Bis(2-ethylhexyl) sebacate polyester. | 双(2乙基己基)癸二酸聚酯 |
G12 | Phenyldiethanolamine succinate polyester. | 苯基二乙醇胺琥珀酸聚酯 |
G13 | Sorbitol. | 山梨醇 |
G14 | Polyethylene glycol (av. mol. wt. of 950 to 1050). | 聚乙二醇(平均分子量950-1,050) |
G15 | Polyethylene glycol (av. mol. wt. of 3000 to 3700). | 聚乙二醇(平均分子量3,000~3,700) |
G16 | Polyethylene glycol compound (av. mol. wt. about 15,000). A high molecular weight compound of polyethylene glycol with a diepoxide linker. [note—Available commercially as Polyethylene Glycol Compound 20M, or as Carbowax 20M, from suppliers of chromatographic reagents.] | 聚乙二醇(平均分子量3,000~3,700) 。聚乙二醇与一种二环氧化物粘合物的高分子合物。[注----商名聚乙二醇合物20M,或Carbowax 20M,色谱试剂商处购得] |
G17 | 75% Phenyl-25% methylpolysiloxane. | 75%苯基-25%甲基聚硅氧烷 |
G18 | Polyalkylene glycol. | 聚亚烷基二醇 |
G19 | 25% Phenyl-25% cyanopropyl-50% methylsilicone. | 25%苯基-25%氰丙基-50%甲基硅氧烷 |
G20 | Polyethylene glycol (av. mol. wt. of 380 to 420). | 聚乙二醇(平均分子量380~420) |
G21 | Neopentyl glycol succinate. | 丁二酸新戊二醇酯(NGS) |
G22 | Bis(2-ethylhexyl) phthalate. | 双(2-乙基己基)邻苯二甲酸酯 |
G23 | Polyethylene glycol adipate. | 聚己二酸乙二醇酯 EGA |
G24 | Diisodecyl phthalate. | 二异癸邻苯二甲酸酯 |
G25 | Polyethylene glycol compound TPA. A high molecular weight compound of a polyethylene glycol and a diepoxide that is esterified with terephthalic acid. [note—Available commercially as Carbowax 20M-TPA from suppliers of chromatographic reagents.] | 聚乙二醇TPA(Carbowax 20M对苯二甲酸)聚乙二醇和二环氧化物的高分子化合物用对苯二甲酸酯化 [注---商业名称:Carbowax 20M-TPA,色谱试剂供应商处可购] |
G26 | 25% 2-Cyanoethyl-75% methylpolysiloxane. | 25%2-氰基乙基-75%甲基聚硅氧烷 |
G27 | 5% Phenyl-95% methylpolysiloxane. | 5%苯基-95%甲基聚硅氧烷 |
G28 | 25% Phenyl-75% methylpolysiloxane. | 25%苯基-75%甲基聚硅氧烷 |
G29 | 3,3?-Thiodipropionitrile. | 3,3’-硫代丙晴 TDPN |
G30 | Tetraethylene glycol dimethyl ether. | 四甘醇二甲基醚 |
G31 | Nonylphenoxypoly(ethyleneoxy)ethanol (av. ethyleneoxy chain length is 30); Nonoxynol 30. | 壬基酚聚氧乙烯醚(平均乙烯氧基链长度30);壬苯醇醚30 |
G32 | 20% Phenylmethyl-80% dimethylpolysiloxane. | 20%苯甲基-80%二甲基聚硅氧烷 |
G33 | 20% Carborane-80% methylsilicone. | 20%碳硼烷-80%甲基硅 |
G34 | Diethylene glycol succinate polyester stabilized with phosphoric acid. | 聚乙二醇丁二酸酯,用磷酸固化 |
G35 | A high molecular weight compound of a polyethylene glycol and a diepoxide that is esterified with nitroterephthalic acid. | 聚乙二醇及硝基对苯二甲酸酯化双环氧化物高分子合物(用硝基对苯二甲酸酯化) |
G36 | 1% Vinyl-5% phenylmethylpolysiloxane. | 1%乙烯基-5%苯甲基聚硅氧烷 |
G37 | Polyimide. | 聚酰亚胺 |
G38 | Phase G1 containing a small percentage of a tailing inhibitor. [note—A suitable grade is available commercially as “SP2100/0.1% Carbowax 1500” from Supelco, Inc. (www.sigmaaldrich.com/supelco).] | G1固定相,加少量拖尾抑制剂 [注----适用级别,商名SP2100/0.1% Carbowax 1500’’厂商Supelco Inc.,网址www.sigmaaldrich.com/supelco] |
G39 | Polyethylene glycol (av. mol. wt. about 1500). | 聚乙二醇(平均分子量1500) |
G40 | Ethylene glycol adipate. | 己二酸乙二醇酯 |
G41 | Phenylmethyldimethylsilicone (10% phenyl-substituted). | 苯甲基二四基聚硅氧烷 (10%苯取代) |
G42 | 35% phenyl-65% dimethylpolysiloxane (percentages refer to molar substitution). | 35%苯基-65%乙烯基硅烷 (百分比参见分子取代度) |
G43 | 6% cyanopropylphenyl-94% dimethylpolysiloxane (percentages refer to molar substitution). | 6%氰丙基苯-94%二甲基聚硅氧烷 (百分比参见分子取代度) |
G44 | 2% low molecular weight petrolatum hydrocarbon grease and 1% solution of potassium hydroxide. | 2%低分子量石油烃脂和1%氢氧化钾溶液 |
G45 | Divinylbenzene-ethylene glycol-dimethylacrylate. | 二乙烯基苯-乙二醇-二甲基丙烯酸酯 |
G46 | 14% Cyanopropylphenyl-86% methylpolysiloxane | 14%-氰丙基苯基-86%-甲基聚硅氧烷 |
G47 | Polyethylene glycol (av. mol. wt. of about 8000). | 聚乙二醇(平均分子量8000) |
G48 | Highly polar, partially cross-linked cyanopolysiloxane. | 强极性,部分交联氰基聚硅氧烷 |
