【Abstract】 Objective To establish the reversed phase high-performance liquid chromatography(RP-HPLC) assay for determination of the content of sodium fusidate for injection.Methods RP-HPLC assay was adopted.Diamonsil C18(250 mm×4.6 mm,5 μm) was chosen as the chromatographic column with UV detection wavelength at 235 nm,and the mobile phase consisting of 0.05mol/L phosphoric acid-acetonitrile-methanol(40∶50∶10) was used;the flow rate was 1.0 mL/min,and the column temperature was 30 ℃.Results The calibration... 更多还原 【关键词】 夫西地酸钠; HPLC; 含量测定; 【Key words】 sodium fusidate; HPLC; content determination;
