【Abstract】 Objective To develop a method for the determination 5-hydroxymethylfural(5-HMF) in ozagrel glucose injection by RP-HPLC.Methods The chromatographic condition Diamonsil C18 column and the mobile phase consisting of a methanol-pH 7.0 phosphate buffer(35:65).The detection wavelength was at 284nm.Results 5-HMF curve was linear over the range of 0.01045~0.01315μg with correlation coeff icient 0.9999.The average recovery was 100.7%.The method precision(RSD) was 0.4%.Conclusion The assay of 5-HMF is fo... 更多还原 【关键词】 5-羟甲基糠醛; 奥扎格雷钠葡萄糖注射液; 高效液相色谱法; 【Key words】 5-hydroxymethylfural; Ozagrel Glucose injection; HPLC;
