【Abstract】 A TLC method for identification of radix paeoniae rubra, radix salviae miltiorrhizae, radix scutellariae, poria and rhizoma sparganii in Chidan pills and a HPLC method for determination of paeonflorin in pills were presented. A Diamonsil C_ 18 column was used with the mobile phase of acetonitrile-water (20∶80), at room temperature and detection wavelength of 230 nm. The calibration curve of paeonflorin was linear in the concentration range of 16~160 μg/ml( r=0.9999) .The average recovery was 99.... 更多还原 【关键词】 赤丹丸; 芍药苷; HPLC; TLC; 测定; 【Key words】 Chidan pills; paeonflorin; HPLC; TLC; determination;
