crystal_cai
第4楼2006/08/25
Yes, the spectra will be different if you use fluoresence spectrometer. The excitation intensity can make difference as well. If you are dealing with bio sample, try to use NIR laser, which will minimize your fluorescence. If you can still see some peak with fluorescence background, there are modeling or mathematical methods you can try. There are publications in these topics.
