求助5篇英文文献,谢谢!
  • 黄土高原
    2013/01/21
文献检索-互助
  • 悬赏金额:10积分状态:已解决
  • 【序号】:1
    【作者】:Jim Peterson
    【题名】:1H NMR analysis of mixtures using internal standards: A quantitative experiment for the instrumental analysis laboratory
    【期刊】:Journal of Chemical Education
    【年、卷、期、起止页码】:1992, 69 (10), p 843
    http://pubs.acs.org/doi/abs/10.1021/ed069p843
    【序号】:2
    【作者】:Thompson, Lynn; Veening, Hans; Strein, Timothy G.
    【题名】:Capillary Electrophoresis in the Undergraduate Instrumental Analysis Laboratory: Determination of Common Analgesic Formulations
    【年、卷、期、起止页码】:vol. 74, Issue 9, p.1117
    【序号】:3
    【作者】:Pandey, Siddarth; Powell, Joyce R.; McHale, Mary E. R.; Acree, William E., Jr.
    【题名】:Modern Instrumental Analysis Laboratory Experiment: Quantitative Determination of Cr (III) and Co (II) Using a Spectroscopic H-Point Standard Addition Method
    【年、卷、期、起止页码】:vol. 74, Issue 7, p.848
    【序号】:4
    【作者】:Quach, Dinh T.; Ciszkowski, Nancy A.; Finlayson-Pitts, Barbara J.
    【题名】:A New gc-MS Experiment for the Undergraduate Instrumental Analysis Laboratory in Environmental Chemistry: Methyl-t-butyl Ether and Benzene in Gasoline
    【年、卷、期、起止页码】:vol. 75, Issue 12, p.1595
    【序号】:5
    【作者】:Girard, James E.; Diamant, Constance T.
    【题名】:Instrumental Analysis Lecture and Laboratory: A Survey
    【年、卷、期、起止页码】:vol. 77, Issue 5, p.646
gpm1976 2013/01/21
11111111
  • 黄土高原
    第6楼2013/01/21
    sorry,第一个打不开,麻烦您帮我再转一下吧,谢谢!
    其他的都可以打开。
    gpm1976(gpm1976) 发表:11111111
  • gpm1976
    第7楼2013/01/22
    又传了一下,应该可以打开的,两个版本我都试过了。
    黄土高原(chemnobel) 发表:sorry,第一个打不开,麻烦您帮我再转一下吧,谢谢!
    其他的都可以打开。
