01 Chemical Routes in the Synthesis of Nanomaterials Using the Sol–Gel Process http://pubs.acs.org/doi/abs/10.1021/ar7000149 02 Nonaqueous Sol–Gel Routes to Metal Oxide Nanoparticles http://pubs.acs.org/doi/abs/10.1021/ar600035e 03 Highly Transparent and Conductive Films of Densely Aligned Ultrathin Au Nanowire Monolayers http://pubs.acs.org/doi/abs/10.1021/nl3021522 04 Colloidal Nanocrystal-Based Gels and Aerogels: Material Aspects and Application Perspectives http://pubs.acs.org/doi/abs/10.1021/jz201357r 05 Manipulation of Charge Transfer Across Semiconductor Interface. A Criterion That Cannot Be Ignored in Photocatalyst Design
