nmrviewer
第7楼2006/09/01
Companies
Bruker Biospin, based in Massachusetts, US, sells a range of NMR equipment, including spectrometers. The company provides superconducting NMR magnets up to 900MHz. It also sells a range of NMR accessories, including cryoprobes and magic angle spinning probes.
Oxford Instruments is based in Oxfordshire, UK. The company sells NMR magnets for ultra-high field applications, offering NMR magnetic field strengths up to 950MHz. It also sells benchtop NMR machines and accessories.
Varian sells NMR magnets and a range of probes including cryoprobes and solid and liquid state probes. It also sells software to deal with data acquisition, processing and analysis.The company is based in Palo Alto, US.
JEOL, based in Tokyo, Japan, provides a range of NMR spectrometers. Its ECX range is available from 300 to 500 MHz field strengths. Meanwhile, its ECA NMR covers 300 to 920MHz. The company also sells NMR probes.
http://www.rsc.org/chemistryworld/restricted/2006/May/NMR3D.asp
有自攒、瞬时高达40T的(>1.6G)。
知之为知之,不知为不知,是知也。
sslin
第8楼2006/09/05
就我所知, 英国的 Oxford 公司主要生产磁体, 本身不生产核磁超导谱仪. 950 兆的谱仪应该没有生产出来.
Varian 公司和 Oxford 合作了几十年, 近期解除了合作关系.
