yuduoling
第4楼2013/07/25
部分化学测试简要步骤,以下面样品为例:
Simple procedure of some chemical test, take the sample below as an example:
一、 甲醛(HCHO)含量的测试步骤:
Procedure of Formaldehyde (HCHO) analysis:
1. 把样品剪碎如下:
cut two test specimens into small pieces as below:
2. 称取平行样各2g,精确到10mg,并装入250ml的带塞锥形瓶中。
weigh approximately 2 g of the pieces to an accuracy of 10 mg, for each test specimen, put the weighed pieces into a 250 ml flask with a stopper.
3. 在锥形瓶中加入100ml超纯水,放入水浴中。在40℃下震荡1小时
Add 100 ml of water into each flask, stop tightly and place in a water bath at (40 2) °C for (60 5) min. Shake the flask at least every 5 min, ensuring that the specimens are entirely wet.
4. 震荡完毕后,立即取出过滤.
Then filter the solution into another flask through a filter.
5. 将样品溶液和显色剂(纳氏试剂)按1:1的比例混合,摇匀。
Put 5 ml of the filtered test specimen solution in tubes, add 5 ml of acetylacetone reagent into each tube and shake them.
6. 然后放入40℃水浴中避光显色半小时,然后室温中放置半小时。
Keep the test tubes first in a water bath at (40 2) °C for (30 5) min and then at ambient temperature for (30 5) min.
7. 用紫外可见分光光度计,置溶液于10mm的比色皿中,在波长412nm处分析样品的吸光度。
Using the UV-VIS spectrophotometer , measure the absorbances in a 10 mm absorption cell at a wavelength of 412 nm.
二、 八大重金属含量测试步骤:
Procedure of Total Heavy Metal (8 elements) analysis:
1. 称取剪碎的样品0.15g于消解罐中,加入10ml浓硝酸(在通风橱中),密封。
Weigh a well-mixed sample near 0.15g into an appropriate vessel equipped with a pressure relief mechanism, add 10± 0.1 mL concentrated nitric acid(in a fume hood), then seal up.
2. 将消解罐放入微波设备中进行消解,过程大概2小时。
Take prepared vessels into microwave system that using microwave heating to digest samples. It will take near 2 hours.
3. 消解完毕冷却后,将样品冲洗定容后,再过滤到小试管中,准备上机。
After cooling, the vessel contents may be filtered, centrifuged, or allowed
to settle and then decanted, diluted to volume.
4. 最后用ICP-OES分析其中重金属的含量
Then analyze the total heavy metals by ICP-OES.
若重金属含量超过限值,则需要做萃取测试,如下:
If the results of total heavy metals exceed the limits, it need to do a migration test.
Below is the procedure of migration test:
1. 称取样品0.2g于50ml的锥形瓶中
Weigh approximately 0.2 g of the pieces into a 25 ml flask.
2. 加入10ml 0.07mol/L的盐酸溶液,在37℃水浴中震荡1小时,再静置1小时
Add 10ml 0,07 mol/l aqueous solution of hydrochloric acid, Agitate the mixture at (37 ±2) °C for 1 h continuously and then allow to stand for 1 h at (37±2) °C.
3. 然后立即取出直接过滤到小试管中准备上机
Without delay, efficiently separate the solids from the solution. The solution be filtered into tubes.
Then analyze the heavy metals of migration by ICP-OES.
End
vicky123win
第6楼2013/07/26
应版主的要求,再编辑一下,大家有什么意见或建议,欢迎随便讨论
部分化学测试简要步骤,以下面样品为例:
Brief procedure of some chemical test, takethe sample below as an example:
一、甲醛(HCHO)含量的测试步骤:
Procedureof Formaldehyde (HCHO) analysis:
1. 把样品剪碎如下:
weigh approximately 2 g of the pieces to an accuracy of 10 mg, for eachtest specimen, put the weighed pieces into a 250 ml flask with a stopper.
Add 100 ml of water intoeach flask, stop tightly and place in a water bath at (40 ±2)°C for (60 ± 5) min. Shake the flask at least every 5 min, ensuring that the specimensare entirely wet.
Keep the test tubes first in a water bath at (40 ± 2)°C for (30 ± 5) min and then at ambient temperature for (30 ± 5)min.
Using the UV-VIS spectrophotometer , measure the absorbances in a 10 mmabsorption cell at a wavelength of 412 nm.
Weigh a well-mixed sample near 0.15g into an appropriate vesselequipped with a pressure relief mechanism, add 10± 0.1 mL concentrated nitricacid(ina fume hood),then seal up.
After cooling, the vessel contents may be filtered, centrifuged, orallowed
Add 10ml 0,07 mol/laqueous solution of hydrochloric acid, Agitate the mixture at (37 ±2) °C for 1h continuously and then allow to stand for 1 h at (37±2) °C.
