ARL直读光谱仪ALARM列表(1)
  • happy_cheng
    2004/01/12
直读光谱
  • 0.ALARM ICS:Instrument busy(executing M1,M2,IS,CS command)
    1.ALARM# ICS:Instrument vacuum out
    2.ALARM# ICS:Instrument temperature out
    3.ALARM# ICS:Mains voltage out
    4.ALARM# ICS:-1000 volt power supply out
    5.ALARM# ICS:cabinet temperature out
    6.ALARM# ICS:+5 volt power supply out
    7.ALARM# ICS:+15 volt power supply out
    8.ALARM# ICS:-15 volt power supply out
    9.ALARM# ICS:+24 volt power supply out
    10.ALARM# ICS:-100 volt power supply out
    11.ALARM# ICS:-10v test out(ICS 35)/+5v SEQ out (ICS34/3520)
    12.ALARM# ICS:-1v test out(ICS 35)/+15v SEQ out (ICS34/3520)
    13.ALARM# ICS:-0.1v test out(ICS 35)/-15v SEQ out (ICS34/3520)
    14.ALARM# ICS:charge converter zero reference out(ICS-35)
    15.ALARM# ICS:CCS/DCU +350 Volt power supply out
    16.ALARM# ICS:CCS/DCU +200 Volt power supply out
    17.ALARM# ICS:CCS/DCU +15 Volt power supply out
    18.ALARM# ICS:CCS/DCU -15 Volt power supply out
    19.ALARM# ICS:CCS/DCU +5 Volt power supply out
    20.ALARM# ICS:CCS/DCU +25 Volt power supply out
    21.ALARM# ICS:Instrument safety circuit broken
    22.ALARM# ICS:Instrument STOP button pressed
    23.ALARM# ICS:Source not running
    24.ALARM# ICS:Lower voltage out
    25.ALARM# ICS:Charge converter overflowor underflow
    ALARM前面的编号是仪器出现警告的编号。是一一对应的。
