这句话还有其它上下文吗?我怎么觉得半天没看懂在说啥呀....
“对提供的测量不确定度进行修正时,应考虑到实验室转移所造成的影响。目的是为了减少不同实验室间在测同一样品时得出的pass/fail结论的异同。”
wuym(wuym) 发表:EN 71-3:2013:The uncertainty of measurements supplied will need revising to take account of between lab migration effects, in order to minimise different pass/fail conclusions being reached by different labs testing the same samples. 实验室间不同迁移效果引入的不确定度该如何评定?
