Chemical | TiO2 | Fe203 | Fe203(Calc) | FeO | Al2O3 | Cr2O3 | MgO | MnO | P2O5 | SO3 | SiO2 | CaO | V2O5 | Nb2O5 | ZrO2 | Zn | U_P | TH_P | As | Pb_PLOI | 1000 | Cu | Density | Hg | Na | C |
Units | % | % | % | % | % | % | % | % | % | % | % | % | % | % | % | ppm | ppm | ppm | ppm | ppm | % | ppm | gm/cc | ppb | % | % |
Detn Limit | 0.01 | 0.01 | 0.01 | 0.05 | 0.01 | 0.001 | 0.01 | 0.01 | 0.001 | 0.001 | 0.01 | 0.01 | 0.01 | 0.001 | 0.01 | 5 | 10 | 10 | 10 | 5 | 0 | 5 | 0.01 | 10 | 0.01 | 0.01 |
Tis Grade | 52 | 44 | 11 | 35 | 0.54 | 0.053 | 0.69 | 0.36 | 0.3 | 0.017 | 0.97 | 0.12 | 0.2 | 0.14 | 0.09 | 545 | 10 | 15 | 10 | 35 | NA | 25 | 4.44 | 10 | 0.05 | NA |
H.T-Grade | 55.9 | 41.1 | 20.5 | 18.3 | 0.58 | 0.1 | 0.78 | 0.38 | 0.5 | 0.017 | 0.89 | 0.16 | 0.16 | 0.162 | 0.09 | 425 |
