汽车线束环境测试Environmental Test | 汽车线束电性能测试 Electrical Performance test |
高温 High Temperature 低温 Low Temperature 热冲击Thermal Shock 温湿度循环 Temperature/Humidity Cycle 振动 Vibration 结合温湿度振动Vibration Combinedwith Temperature/Humidity 盐雾Salt Water Resistance 老化 Ageing 防尘 Dust Resistance 密封Sealing 化学试液 Chemical Resistance 耐电池液Battery Acid Resistance 气体腐蚀Corrosive Gases Resistance | 绝缘电阻 Insulation Resistance 介电强度Dielectric strength 电流循环Current Cycle 反复连接/断开寿命Repetitive Insertion and Removal 接触电阻(电压降) Voltage Drop 温升性能 Temperature Rise 耐燃Non-Flammability 线路导通Conduction Test |
汽车线束机械性能测试,Mechanical,Performance,test | |
挤压Crimping耐磨Abrasion Resistant低温卷绕 Bending Test at Low Temperature 低温抗冲击Low Temperature Impact 热收缩Shrinking 端子插入力/拔出力/保持力 Connector insertion/removal force/holding force 机械冲击Mechanical Shock 抗跌落性能Drop-impact Resistance 高温高压喷水(IPX9K)High Pressure Water Spray切片 Slicing撕裂力 InsulationStripability 线间互磨AbrationResistanceofWireAgainstWire 滑动拉力 SlidingBehavior 弯折力 BendingForce 绝缘缺口强度 InsulationNotchStrength |
